I have been following this thread:
Jetpack 4.2 failed to install on target - Jetson & Embedded Systems / Jetson TX2 - NVIDIA Developer Forums
I have a similar issue but haven’t able to solve it. I am doing this on a Xavier AGX
I need to install jetpack 4.2 because thats what our devices were originally built on and there is not an easy way to work with a new jetpack.
I am running sdkmanager --archivedversions and it’s downloaded but it’s struggling in particular with the AI packages.
Here is the error log-
12:38:39 ERROR: cuDNN on Target - target: DevZone get download url failed: HTTPError: Response code 403 (Forbidden) .
12:38:39 ERROR: cuDNN on Target - target: Download ‘cuDNN on Target’ failure
12:38:39 ERROR: cuDNN on Target - target: download failed
12:38:39 : cuDNN on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P2888/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb failed, retrying 2…
12:38:40 INFO: cuDNN on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P2888/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb to /home/nvidia/Downloads/nvidia/sdkm_downloads/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb
12:38:40 ERROR: cuDNN on Target - target: DevZone get download url failed: HTTPError: Response code 403 (Forbidden) .
12:38:40 ERROR: cuDNN on Target - target: Download ‘cuDNN on Target’ failure
12:38:40 ERROR: cuDNN on Target - target: download failed
12:38:40 : cuDNN on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P2888/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb failed, retrying 3…
12:38:40 INFO: cuDNN on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P2888/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb to /home/nvidia/Downloads/nvidia/sdkm_downloads/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb
12:38:41 ERROR: cuDNN on Target - target: DevZone get download url failed: HTTPError: Response code 403 (Forbidden) .
12:38:41 ERROR: cuDNN on Target - target: Download ‘cuDNN on Target’ failure
12:38:41 ERROR: cuDNN on Target - target: download failed
12:38:41 : cuDNN on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P2888/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb failed, retrying 3…
12:38:41 INFO: cuDNN on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P2888/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb to /home/nvidia/Downloads/nvidia/sdkm_downloads/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb
12:38:42 ERROR: cuDNN on Target - target: DevZone get download url failed: HTTPError: Response code 403 (Forbidden) .
12:38:42 ERROR: cuDNN on Target - target: Download ‘cuDNN on Target’ failure
12:38:42 ERROR: cuDNN on Target - target: download failed
12:38:42 : cuDNN on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P2888/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb failed, retrying 4…
12:38:42 INFO: cuDNN on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P2888/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb to /home/nvidia/Downloads/nvidia/sdkm_downloads/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb
12:38:42 : cuDNN on Target - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P2888/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb failed, retrying 4…
12:38:42 INFO: cuDNN on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P2888/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb to /home/nvidia/Downloads/nvidia/sdkm_downloads/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb
12:38:43 INFO: cuDNN on Target - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2/JETPACK_42_b158/P2888/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb to /home/nvidia/Downloads/nvidia/sdkm_downloads/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb
12:38:43 ERROR: cuDNN on Target - target: DevZone get download url failed: HTTPError: Response code 403 (Forbidden) .
12:38:43 ERROR: cuDNN on Target - target: Download ‘cuDNN on Target’ failure
12:38:43 ERROR: cuDNN on Target - target: download failed
12:38:44 ERROR: cuDNN on Target - target: DevZone get download url failed: HTTPError: Response code 403 (Forbidden) .
12:38:44 ERROR: cuDNN on Target - target: Download ‘cuDNN on Target’ failure
12:38:44 ERROR: cuDNN on Target - target: download failed
DOWNLOAD FAILED
Please review the terminal tab for details. Resolve and RETRY.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2022, NVIDIA CORPORATION. All rights reserved. | NVIDIA Developer
I have tried downloading the packages manually and putting them in the sdk_downloads folder but when I run flashing script through the sdk manager it still fails on these.
Ultimately I’m trying to clone one of our production devices, but when I clone it, the system.img is like 350mb. When I flash it to a new device, it can’t even boot up properly.
Thats the end goal and I figured the fact sdk_downloads not having all the packages it needs is the root cause of the issue so I’m trying to solve that first.
