I am using ubuntu on VMware and using the SDK to do the installation, but at around 30% stops and I cannot get the agx flash, so I had to navigate to
cd ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra
and run
sudo ./flash.sh jetson-xavier mmcblk0p1
So to get the AGX flashed and booted, but after I cannot install Cuda, Deepstream, Tensor and so on and I m using this script to proceed.
It broke a couple of times and had to do a sudo fix broken all. Now seems to be ok but I want to be sure that it is properly installed. At the moment I am running some cuda example and seems to be ok. Now I need to install OpenCV and I am referring to this script. Which I tried before and did not end up well.
My questions are:
How do I check that my installation is valid?
How do I install OpenCV without NVMe?
At the moment OpenCV 4.5 is installed and seems to work, I installed darknet from this tutorial and seems to work. Now I need to add YOLO and I might have to start over with this other repo
The “script” is probably a bit outdated, but might work ok.
You should know that the failure to complete a flash is due to the VM not being set up correctly to always pass the USB device (the recovery mode Jetson) through even if it disconnects and reconnects. That would be something to ask the VM people’s support about.
If your system is already flashed, then you can skip all of that manual install information and simply use JetPack/SDKM. What you’d do is to fully boot the Jetson without recovery mode, and then in JetPack/SDKM you would deselect flash and deselect any host side install and simply enable install of the components to Jetson. In this case it uses ethernet. The default is the IP address of the virtual wired ethernet on the USB-C, and this would then have to be set up in the parent host PC o/s to pass through to the child Ubuntu o/s (this is a “standard” USB ethernet device with no special drivers, so if it reaches the VM, then it could be set up).
