Hi,WayneWWW. Thanks for your reply.
Here is the old sd card booting fail (The screen show Nvidia logo with white background)log:
[0000.306] Processing in cold boot mode Bootloader 2
[0000.311] A02 Bootrom Patch rev = 1023
[0000.314] Power-up reason: pmc por
[0000.317] No Battery Present
[0000.320] pmic max77620 reset reason
[0000.323] pmic max77620 NVERC : 0x40
[0000.327] RamCode = 0
[0000.329] Platform has DDR4 type RAM
[0000.332] max77620 disabling SD1 Remote Sense
[0000.337] Setting DDR voltage to 1125mv
[0000.341] Serial Number of Pmic Max77663: 0x1603b1
[0000.348] Entering ramdump check
[0000.351] Get RamDumpCarveOut = 0x0
[0000.354] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.360] Last reboot was clean, booting normally!
[0000.364] Sdram initialization is successful
[0000.368] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.374] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.380] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.386] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.392] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.398] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.404] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.409] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.426] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.432] Platform-DebugCarveout: 0
[0000.435] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.441] Non secure mode, and RB not enabled.
[0000.445] BoardID = 3448, SKU = 0x0
[0000.448] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.452] Nano-SD: checking PT table on QSPI ...
[0000.456] Read PT from (2:0)
[0000.472] Using BFS PT to query partitions
[0000.478] Loading Tboot-CPU binary
[0000.506] Verifying TBC in OdmNonSecureSBK mode
[0000.516] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.523] Bootloader downloaded successfully.
[0000.527] Downloaded Tboot-CPU binary to 0xa0000258
[0000.532] MAX77620_GPIO5 configured
[0000.535] CPU power rail is up
[0000.538] CPU clock enabled
[0000.542] Performing RAM repair
[0000.545] Updating A64 Warmreset Address to 0xa00002e9
[0000.550] BoardID = 3448, SKU = 0x0
[0000.553] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.557] Nano-SD: checking PT table on QSPI ...
[0000.561] Loading NvTbootBootloaderDTB
[0000.628] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.701] Bootloader DTB Load Address: 0x83000000
[0000.706] BoardID = 3448, SKU = 0x0
[0000.709] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.713] Nano-SD: checking PT table on QSPI ...
[0000.717] Loading NvTbootKernelDTB
[0000.783] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.856] Kernel DTB Load Address: 0x83100000
[0000.860] BoardID = 3448, SKU = 0x0
[0000.864] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.868] Nano-SD: checking PT table on QSPI ...
[0000.874] Loading cboot binary
[0000.989] Verifying EBT in OdmNonSecureSBK mode
[0001.031] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.038] Bootloader downloaded successfully.
[0001.042] BoardID = 3448, SKU = 0x0
[0001.046] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.049] Nano-SD: checking PT table on QSPI ...
[0001.054] PT: Partition NCT NOT found !
[0001.058] Warning: Find Partition via PT Failed
[0001.062] Next binary entry address: 0x92c00258
[0001.067] BoardId: 3448
[0001.082] NvTbootI2cWaitForTransferComplete(): error code 0x00000005 I2C Transaction could not complete within time
[0001.103] NvTbootI2cWaitForTransferComplete(): error code 0x00000005 I2C Transaction could not complete within time
[0001.113] NvTbootI2cWrite(): error code 0x00000005 Error while starting write transaction
[0001.120] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave
[0001.129] NvTbootI2c: Read failed for slave 0xaa, offset 0x00 with error code 0x00045001
[0001.137] Overriding pmu board id with proc board id
[0001.152] NvTbootI2cWaitForTransferComplete(): error code 0x00000005 I2C Transaction could not complete within time
[0001.173] NvTbootI2cWaitForTransferComplete(): error code 0x00000005 I2C Transaction could not complete within time
[0001.183] NvTbootI2cWrite(): error code 0x00000005 Error while starting write transaction
[0001.190] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave
[0001.199] NvTbootI2c: Read failed for slave 0xa2, offset 0x00 with error code 0x00045001
[0001.207] Display board id is not available
[0001.211] BoardID = 3448, SKU = 0x0
[0001.214] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.218] Nano-SD: checking PT table on QSPI ...
[0001.323] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.380] /bpmp deleted
[0001.382] SC7EntryFw header found loaded at 0xff700000
[0001.577] OVR2 PMIC
[0001.579] Bpmp FW successfully loaded
[0001.583] BoardID = 3448, SKU = 0x0
[0001.586] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.590] Nano-SD: checking PT table on QSPI ...
[0001.595] WB0 init successfully at 0xff780000
[0001.599] Set NvDecSticky Bits
[0001.603] GSC2 address ff53fffc value c0edbbcc
[0001.609] GSC MC Settings done
[0001.612] BoardID = 3448, SKU = 0x0
[0001.615] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.619] Nano-SD: checking PT table on QSPI ...
[0001.625] TOS Image length 53680
[0001.628] Monitor size 53680
[0001.630] OS size 0
[0001.646] Secure Os AES-CMAC Verification Success!
[0001.650] TOS image cipher info: plaintext
[0001.654] Loading and Validation of Secure OS Successful
[0001.670] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.675] NvTbootPackSdramParams: start.
[0001.680] NvTbootPackSdramParams: done.
[0001.684] Tegraboot started after 51831 us
[0001.687] Basic modules init took 1200586 us
[0001.692] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.697] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.703] Next stage binary read took 102860 us
[0001.707] Carveout took -260250 us
[0001.710] CPU initialization took 629296 us
[0001.714] Total time taken by TegraBoot 1672492 us
[0001.719] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 08:37:40, Feb 19 2021
ERROR: Error initializing runtime service trusty_fast
[0001.841] RamCode = 0
[0001.846] LPDDR4 Training: Read DT: Number of tables = 2
[0001.851] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.864] EMC Training Successful
[0001.867] 408000 not found in DVFS table
[0001.873] RamCode = 0
[0001.877] DT Write: emc-table@204000 succeeded
[0001.882] DT Write: emc-table@1600000 succeeded
[0001.886] LPDDR4 Training: Write DT: Number of tables = 2
[0001.940]
[0001.942] Debug Init done
[0001.944] Marked DTB cacheable
[0001.947] Bootloader DTB loaded at 0x83000000
[0001.952] Marked DTB cacheable
[0001.955] Kernel DTB loaded at 0x83100000
[0001.959] DeviceTree Init done
[0001.972] Pinmux applied successfully
[0001.976] gicd_base: 0x50041000
[0001.979] gicc_base: 0x50042000
[0001.982] Interrupts Init done
[0001.987] Using base:0x60005090 & irq:208 for tick-timer
[0001.992] Using base:0x60005098 for delay-timer
[0001.996] platform_init_timer: DONE
[0002.000] Timer(tick) Init done
[0002.003] osc freq = 38400 khz
[0002.007]
[0002.008] Welcome to L4T Cboot
[0002.011]
[0002.013] Cboot Version: 00.00.2018.01-t210-39562017
[0002.017] calling constructors
[0002.020] initializing heap
[0002.023] initializing threads
[0002.026] initializing timers
[0002.029] creating bootstrap completion thread
[0002.033] top of bootstrap2()
[0002.036] CPU: ARM Cortex A57
[0002.039] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0002.044] initializing platform
[0002.051] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0002.056] ID LSB = 0x36, ID-CFI len = 194 bytes
[0002.060] Macronix QSPI chip present
[0002.064] SPI device register
[0002.067] init boot device
[0002.069] allocating memory for boot device(SPI)
[0002.074] registering boot device
[0002.082] QSPI bdev is already initialized
[0002.086] Enable APE clock
[0002.089] Un-powergate APE partition
[0002.092] of_register: registering tegra_udc to of_hal
[0002.097] of_register: registering inv20628-driver to of_hal
[0002.103] of_register: registering ads1015-driver to of_hal
[0002.109] of_register: registering lp8557-bl-driver to of_hal
[0002.114] of_register: registering bq2419x_charger to of_hal
[0002.120] of_register: registering bq27441_fuel_gauge to of_hal
[0002.132] gpio framework initialized
[0002.135] of_register: registering tca9539_gpio to of_hal
[0002.140] of_register: registering tca9539_gpio to of_hal
[0002.146] of_register: registering i2c_bus_driver to of_hal
[0002.151] of_register: registering i2c_bus_driver to of_hal
[0002.157] of_register: registering i2c_bus_driver to of_hal
[0002.162] pmic framework initialized
[0002.166] of_register: registering max77620_pmic to of_hal
[0002.171] regulator framework initialized
[0002.175] of_register: registering tps65132_bl_driver to of_hal
[0002.181] initializing target
[0002.187] gpio_driver_register: register 'tegra_gpio_driver' driver
[0002.195] board ID = D78, board SKU = 0
[0002.199] Skipping Z3!
[0002.204] fixed regulator driver initialized
[0002.221] initializing OF layer
[0002.224] NCK carveout not present
[0002.228] Skipping dts_overrides
[0002.232] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.249] I2C Bus Init done
[0002.252] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.262] I2C Bus Init done
[0002.265] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.275] I2C Bus Init done
[0002.278] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.288] I2C Bus Init done
[0002.291] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.301] I2C Bus Init done
[0002.304] of_children_init: Ops found for compatible string maxim,max77620
[0002.314] max77620_init using irq 118
[0002.319] register 'maxim,max77620' pmic
[0002.323] gpio_driver_register: register 'max77620-gpio' driver
[0002.329] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.340] I2C Bus Init done
[0002.344] NCK carveout not present
[0002.353] Find /i2c@7000c000's alias i2c0
[0002.357] get eeprom at 1-a0, size 256, type 0
[0002.366] Find /i2c@7000c500's alias i2c2
[0002.370] get eeprom at 3-a0, size 256, type 0
[0002.374] get eeprom at 3-ae, size 256, type 0
[0002.379] pm_ids_update: Updating 1,a0, size 256, type 0
[0004.384] I2C transfer timeout
[0004.387] I2C write failed
[0004.390] Writing offset failed
[0004.393] eeprom_init: EEPROM read failed
[0004.397] pm_ids_update: eeprom init failed
[0004.401] pm_ids_update: Updating 3,a0, size 256, type 0
[0004.431] pm_ids_update: The pm board id is 3448-0000-400
[0004.438] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0004.446] pm_ids_update: pm id update successful
[0004.451] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.481] pm_ids_update: The pm board id is 3449-0000-400
[0004.487] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0004.495] pm_ids_update: pm id update successful
[0004.525] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.531] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0004.539] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.545] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0004.553] updating /chosen/nvidia,ethernet-mac node 00:04:4b:ec:b1:9e
[0004.560] Plugin Manager: Parse ODM data 0x000a4000
[0004.572] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0004.587] Find /i2c@7000c000's alias i2c0
[0004.591] get eeprom at 1-a0, size 256, type 0
[0004.600] Find /i2c@7000c500's alias i2c2
[0004.603] get eeprom at 3-a0, size 256, type 0
[0004.608] get eeprom at 3-ae, size 256, type 0
[0004.612] pm_ids_update: Updating 1,a0, size 256, type 0
[0006.618] I2C transfer timeout
[0006.621] I2C write failed
[0006.623] Writing offset failed
[0006.626] eeprom_init: EEPROM read failed
[0006.630] pm_ids_update: eeprom init failed
[0006.634] pm_ids_update: Updating 3,a0, size 256, type 0
[0006.664] pm_ids_update: The pm board id is 3448-0000-400
[0006.671] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0006.678] pm_ids_update: pm id update successful
[0006.682] pm_ids_update: Updating 3,ae, size 256, type 0
[0006.712] pm_ids_update: The pm board id is 3449-0000-400
[0006.718] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0006.725] pm_ids_update: pm id update successful
[0006.756] Add serial number:1420121032620 as DT property
[0006.763] Applying platform configs
[0006.770] platform-init is not present. Skipping
[0006.775] calling apps_init()
[0006.780] Couldn't find GPT header
[0006.785] Proceeding to Cold Boot
[0006.788] starting app android_boot_app
[0006.792] Device state: unlocked
[0006.795] display console init
[0006.803] could not find regulator
[0006.827] hdmi cable not connected
[0006.830] is_hdmi_needed: HDMI not connected, returning false
[0006.836] hdmi is not connected
[[0006.842] DT entry for leds-pwm not found
0006.839] sor0 is not supported
[0006.849] display_console_init: no valid display out_type
[0006.857] subnode volume_up is not found !
[0006.861] subnode back is not found !
[0006.865] subnode volume_down is not found !
[0006.869] subnode menu is not found !
[0006.873] Gpio keyboard init success
[0006.953] found decompressor handler: lz4-legacy
[0006.968] decompressing blob (type 1)...
[0007.034] display_resolution: No display init
[0007.038] Failed to retrieve display resolution
[0007.043] Could not load/initialize BMP blob...ignoring
[0007.117] decompressor handler not found
[0007.121] load_firmware_blob: Firmware blob loaded, entries=2
[0007.127] XUSB blob version 0 size 124416 @ 0x92ca828c
[0007.133] -------> se_aes_verify_sbk_clear: 747
[0007.137] se_aes_verify_sbk_clear: Error
[0007.141] SE operation failed
[0007.144] bl_battery_charging: connected to external power supply
[0007.153] display_console_ioctl: No display init
[0007.158] switch_backlight failed
[0007.164] device_query_partition_size: failed to open partition spiflash0:MSC !
[0007.171] MSC Partition not found
[0007.178] device_query_partition_size: failed to open partition spiflash0:USP !
[0007.185] USP partition read failed!
[0007.188] blob_init: blob-partition USP header read failed
[0007.194] android_boot Unable to update recovery partition
[0007.199] kfs_getpartname: name = LNX
[0007.203] Loading kernel from LNX
[0007.212] Found 19 BFS partitions in "spiflash0"
[0007.531] load kernel from storage
[0007.536] decompressor handler not found
[0007.801] Successfully loaded kernel and ramdisk images
[0007.806] board ID = D78, board SKU = 0
[0007.811] sdmmc node status = okay
[0007.814] sdcard instance = 0
[0007.817] sdcard gpio handle 0x5b
[0007.820] sdcard gpio pin 0xc9
[0007.823] sdcard gpio flags 0x0
[0007.826] vmmc-supply 0x9e
[0007.829] cd_gpio_pin = 201
[0007.831] pin_state = 0
[0007.834] Found sdcard
[0007.836] SD-card IS present ...
[0007.839] load_and_boot_kernel: SD card detected OK
[0007.845] display_resolution: No display init
[0007.849] Failed to retrieve display resolution
[0007.853] bmp blob is not loaded and initialized
[0007.858] Failed to display boot-logo
[0007.862] NCK carveout not present
[0007.865] Skipping dts_overrides
[0007.868] NCK carveout not present
[0007.878] Find /i2c@7000c000's alias i2c0
[0007.882] get eeprom at 1-a0, size 256, type 0
[0007.891] Find /i2c@7000c500's alias i2c2
[0007.895] get eeprom at 3-a0, size 256, type 0
[0007.899] get eeprom at 3-ae, size 256, type 0
[0007.903] pm_ids_update: Updating 1,a0, size 256, type 0
[0009.909] I2C transfer timeout
[0009.912] I2C write failed
[0009.914] Writing offset failed
[0009.917] eeprom_init: EEPROM read failed
[0009.921] pm_ids_update: eeprom init failed
[0009.925] pm_ids_update: Updating 3,a0, size 256, type 0
[0009.956] pm_ids_update: The pm board id is 3448-0000-400
[0009.962] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0009.971] pm_ids_update: pm id update successful
[0009.975] pm_ids_update: Updating 3,ae, size 256, type 0
[0010.005] pm_ids_update: The pm board id is 3449-0000-400
[0010.012] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0010.020] pm_ids_update: pm id update successful
[0010.050] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0010.056] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0010.064] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0010.069] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0010.078] updating /chosen/nvidia,ethernet-mac node 00:04:4b:ec:b1:9e
[0010.084] Plugin Manager: Parse ODM data 0x000a4000
[0010.096] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0010.105] Add serial number:1420121032620 as DT property
[0010.114] "bpmp" doesn't exist, creating
[0010.120] Updated bpmp info to DTB
[0010.124] Updated initrd info to DTB
[0010.128] "proc-board" doesn't exist, creating
[0010.134] Updated board info to DTB
[0010.137] "pmu-board" doesn't exist, creating
[0010.143] Updated board info to DTB
[0010.146] "display-board" doesn't exist, creating
[0010.152] Updated board info to DTB
[0010.156] "reset" doesn't exist, creating
[0010.160] Updated reset info to DTB
[0010.164] display_console_ioctl: No display init
[0010.168] display_console_ioctl: No display init
[0010.173] display_console_ioctl: No display init
[0010.178] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt
[0010.212] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0010.218] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0010.231] Updated bootarg info to DTB
[0010.235] Adding uuid 00000001645106490c00000013fd0280 to DT
[0010.241] Adding eks info 0 to DT
[0010.246] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0010.252] Updated memory info to DTB
[0010.260] set vdd_core voltage to 1075 mv
[0010.264] setting 'vdd-core' regulator to 1075000 micro volts
[0010.270] Found secure-pmc; disable BPMP
U-Boot 2020.04-g6b630d64fd (Feb 19 2021 - 08:37:46 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash... SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 2 1 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1140 bytes read in 20 ms (55.7 KiB/s)
L4T boot options
1: primary kernel
2: Custom 40-pin Header Config
Enter choice: 2: Custom 40-pin Header Config
Retrieving file: /boot/initrd
5488163 bytes read in 253 ms (20.7 MiB/s)
Retrieving file: /boot/Image
34330632 bytes read in 1499 ms (21.8 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
Retrieving file: /boot/tegra210-p3448-0000-p3449-0000-b00-user-custom.dtb
216019 bytes read in 30 ms (6.9 MiB/s)
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083000000, end 0000000083037bd2
copying carveout for /host1x@50000000/dc@54200000...
copying carveout for /host1x@50000000/dc@54240000...
DT property /chosen/nvidia,bluetooth-mac missing in source; can't copy
DT property /chosen/nvidia,wifi-mac missing in source; can't copy
DT property /psci/nvidia,system-lp0-disable missing in source; can't copy
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3456) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 25 21:25:44 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefa8000 s61656 r8192 d32552 u102400
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29448(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3570220K/4159488K available (15294K kernel code, 2934K rwdata, 6640K rodata, 8576K init, 609K bss, 114132K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13d808 ( 2935 KB)
[ 0.000000] .bss : 0xffffff800a13d808 - 0xffffff800a1d5f7c ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.010114] Console: colour dummy device 80x25
[ 0.014763] console [tty0] enabled
[ 0.018273] bootconsole [uart8250] disabled
