I read in the changelog that " V4L2 API is extended to support interacting with CSI Camera. Implementation is compliant with V4L2 spec."
I though this meant we can now use CSI cam directly like USB cams.
When I have a Raspberry pi cam v2 connected to the Jetson I see that it is detected:
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'RG10'
Name : 10-bit Bayer RGRG/GBGB
Size: Discrete 3264x2464
Interval: Discrete 0.048s (21.000 fps)
Size: Discrete 3264x1848
Interval: Discrete 0.036s (28.000 fps)
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Size: Discrete 1640x1232
Interval: Discrete 0.017s (60.000 fps)
But trying to launch it doesn’t works… For example if I open Cheese I don’t have anything… or if I try to launch it like this: "v4l2src device=/dev/video0 ! video/x-raw, framerate=30/1, width=1280, height=720 ! videoconvert ! appsink" , I get an error.
Did I misunderstood the changelog and we still need to use nvarguscamerasrc ?
