@seeky15 the above features will be supported with next JetPack release.
I have the same error , your system is ok?
After
sudo apt update; sudo apt upgrade
again, it worked well.
@suhash May I ask you a question?
Perhaps we should wait for corrections in Jetpack 5.1 ?
Xavier NX 5.0.1, tried to update to 5.0.2 with procedure begining of this post.
load of errors, board reboots without X11.
accessible from network in ssh.
root@ubuntu:/etc/X11# apt-get upgrade
Reading package lists… Done
Building dependency tree
Reading state information… Done
Calculating upgrade… Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
6 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
Setting up nvidia-l4t-bootloader (35.1.0-20220810203728) …
3668-100—1–jetson-xavier-nx-devkit-qspi-
Starting bootloader post-install procedure.
ERROR. Procedure for bl_only_payload update FAILED.
Cannot install package. Exiting…
dpkg: error processing package nvidia-l4t-bootloader (–configure):
installed nvidia-l4t-bootloader package post-installation script subprocess returned error exit status 1
Setting up nvidia-l4t-kernel (5.10.104-tegra-35.1.0-20220810203728) …
Using the existing boot entry ‘primary’
Starting kernel post-install procedure.
ERROR. Procedure for kernel update FAILED.
dpkg: error processing package nvidia-l4t-kernel (–configure):
installed nvidia-l4t-kernel package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-headers:
nvidia-l4t-kernel-headers depends on nvidia-l4t-kernel (= 5.10.104-tegra-35.1.0-20220810203728); however:
Package nvidia-l4t-kernel is not configured yet.
dpkg: error processing package nvidia-l4t-kernel-headers (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-l4t-jetson-io:
nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (>> 5.10.104-tegra-35.1-0); however:
nvidia-l4t-jetson-io depends on nvidia-l4t-kernel (<< 5.10.104-tegra-35.2-0); however:
dpkg: error processing package nvidia-l4t-jetson-io (–configure):
dpkg: dependency problems prevent configuration of nvidia-l4t-display-kernel:
nvidia-l4t-display-kernel depends on nvidia-l4t-kernel (= 5.10.104-tegra-35.1.0-20220810203728); however:
dpkg: error processing package nvidia-l4t-display-kernel (–configure):
No apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of nvidia-l4t-kernel-dtbs:
nvidia-l4t-kernel-dtbs depends on nvidia-l4t-kernel (= 5.10.104-tegra-35.1.0-20220810203728); however:
dpkg: error processing package nvidia-l4t-kernel-dtbs (–configure):
Errors were encountered while processing:
nvidia-l4t-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@ubuntu:/etc/X11# dpkg -l |grep nvidia-l4t
ii nvidia-l4t-3d-core 35.1.0-20220825113828 arm64 NVIDIA GL EGL Package
ii nvidia-l4t-apt-source 35.1.0-20220810203728 arm64 NVIDIA L4T apt source list debian package
iF nvidia-l4t-bootloader 35.1.0-20220810203728 arm64 NVIDIA Bootloader Package
ii nvidia-l4t-camera 35.1.0-20220825113828 arm64 NVIDIA Camera Package
ii nvidia-l4t-configs 35.1.0-20220810203728 arm64 NVIDIA configs debian package
ii nvidia-l4t-core 35.1.0-20220825113828 arm64 NVIDIA Core Package
ii nvidia-l4t-cuda 35.1.0-20220825113828 arm64 NVIDIA CUDA Package
iU nvidia-l4t-display-kernel 5.10.104-tegra-35.1.0-20220810203728 arm64 NVIDIA Display Kernel Modules Package
ii nvidia-l4t-firmware 35.1.0-20220825113828 arm64 NVIDIA Firmware Package
ii nvidia-l4t-gbm 35.1.0-20220825113828 arm64 NVIDIA GBM Package
ii nvidia-l4t-gputools 35.1.0-20220810203728 arm64 NVIDIA dgpu helper Package
ii nvidia-l4t-graphics-demos 35.1.0-20220825113828 arm64 NVIDIA graphics demo applications
ii nvidia-l4t-gstreamer 35.1.0-20220825113828 arm64 NVIDIA GST Application files
ii nvidia-l4t-init 35.1.0-20220825113828 arm64 NVIDIA Init debian package
ii nvidia-l4t-initrd 35.1.0-20220810203728 arm64 NVIDIA initrd debian package
iU nvidia-l4t-jetson-io 35.1.0-20220810203728 arm64 NVIDIA Jetson.IO debian package
ii nvidia-l4t-jetson-multimedia-api 35.1.0-20220825113828 arm64 NVIDIA Jetson Multimedia API is a collection of lower-level APIs that support flexible application development.
ii nvidia-l4t-jetsonpower-gui-tools 35.1.0-20220825113828 arm64 NVIDIA Jetson Power GUI Tools debian package
iF nvidia-l4t-kernel 5.10.104-tegra-35.1.0-20220810203728 arm64 NVIDIA Kernel Package
iU nvidia-l4t-kernel-dtbs 5.10.104-tegra-35.1.0-20220810203728 arm64 NVIDIA Kernel DTB Package
iU nvidia-l4t-kernel-headers 5.10.104-tegra-35.1.0-20220810203728 arm64 NVIDIA Linux Tegra Kernel Headers Package
ii nvidia-l4t-libvulkan 35.1.0-20220825113828 arm64 NVIDIA Vulkan Loader Package
ii nvidia-l4t-multimedia 35.1.0-20220825113828 arm64 NVIDIA Multimedia Package
ii nvidia-l4t-multimedia-utils 35.1.0-20220825113828 arm64 NVIDIA Multimedia Package
ii nvidia-l4t-nvfancontrol 35.1.0-20220825113828 arm64 NVIDIA Nvfancontrol debian package
ii nvidia-l4t-nvpmodel 35.1.0-20220825113828 arm64 NVIDIA Nvpmodel debian package
ii nvidia-l4t-nvpmodel-gui-tools 35.1.0-20220825113828 arm64 NVIDIA Nvpmodel GUI Tools debian package
ii nvidia-l4t-nvsci 35.1.0-20220825113828 arm64 NVIDIA NvSci Package
ii nvidia-l4t-oem-config 35.1.0-20220810203728 arm64 NVIDIA OEM-Config Package
ii nvidia-l4t-optee 35.1.0-20220810203728 arm64 OP-TEE userspace daemons, test programs and libraries
ii nvidia-l4t-pva 35.1.0-20220825113828 arm64 NVIDIA PVA Package
ii nvidia-l4t-tools 35.1.0-20220810203728 arm64 NVIDIA Public Test Tools Package
ii nvidia-l4t-wayland 35.1.0-20220825113828 arm64 NVIDIA Wayland Package
ii nvidia-l4t-weston 35.1.0-20220825113828 arm64 NVIDIA Weston Package
ii nvidia-l4t-x11 35.1.0-20220825113828 arm64 NVIDIA X11 Package
ii nvidia-l4t-xusb-firmware 35.1.0-20220810203728 arm64 NVIDIA USB Firmware Package
