I follow steps to build FFMEPG on Jetpack 5.1.3, but I can’t find libnvbuf_utils.so on Jetson Xavier NX without get any error when building FFMPEG.
I freshly installed jetpack 5.1.2 on my jetson xavier nx development kit through the sdk manager and I want to use hardware accelerated ffmpeg on it.
So I followed this tutorial to install ffmpeg and run it.
However, it report this error.
ffmpeg: error while loading shared libraries: libnvbuf_utils.so.1.0.0: cannot open shared object file: No such file or directory
Then I try to find this library under the directory /usr/lib/aarch64-linux-gnu/tegra
ls /usr/lib/aarch64-linux-gnu/tegra | gre…
May I know how to fix it ? and any reference to use another binary to instead of libnvbuf_utils ?
Thank you.
Thanks DaneLLL,
I already use your ticket to build FFMPEG and also can use FFMPEG to decode.
May I know where can get libnvbuf_utils related module ? No related binaries found under “/usr/lib/aarch64-linux-gnu/tegra/”
NvBuffer APIs are deprecated so libnvbuf_utils.so is removed. We now use NvBufSurface APIs
system
Closed
May 22, 2024, 6:35am
7
