Jetpack 5.1 - Is boot from SD Card supported for ORIN AGX?
According to this topic https://forums.developer.nvidia.com/t/jetson-xavier-nx-not-booting-jetpack-v5/221149 there was an issue with booting from SD card for jetpack 5.0.
I have upgraded my development kits (orin agx and xavier nx) to jetpack 5.1. Is boot from SD card supported?
Thank you,
Rinat
Hi rinat.m,
Sorry, the link looks corrupted or the topic has been removed so that I can not see that.
Yes, it should support boot from SD.
You could refer to the following instruction to do this.
Flashing Support — Flashing with initrd(Flashing Support — Jetson Linux Developer Guide documentation)
You are right. I fixed the link. I will try to use the guide
Thanks,
Rinat
Just to clarify for me - Was it fixed in 5.1? because it was an issue in 5.0.2
Thanks again,
Rinat
It should be supported.
Could you help to use current Jetpack5.1.1(R35.3.1) to verify?
If there’s any issue, then we could debug on the latest version.
