Hello everyone,
I am using a Holybro Jetson (Orin NX 16GB) Pixhawk (6 Pro) Baseboard with JetPack 6.2 installed. After shutting down the Jetson, instead of turning off completely, the screen displays a white screen. This issue did not occur when I was using JetPack 6.1
Any suggestions or insights would be greatly appreciated.
As that is a custom board, please clarify whether that is a HDMI port or DP port on the carrier board first.
Hello! thanks for answering, it’s a mini HDMI port. It’s a modification from the custom board
Could you share the result of xrandr from ssh terminal or UART console?
$export DISPLAY=:0
$xrandr
Hello @WayneWWW sorry for the delay, I didn’t have the companion for a while. This is the output (I had to use 1 because it appears when I use who:
$ export DISPLAY=:1
$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 800mm x 330mm
1920x1080 60.00*+ 59.94 50.00
1680x1050 59.95
1280x1024 75.02 60.02
1280x960 60.00
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
Your software setting is wrong. When you saw “DP” in xrandr, but you are using HDMI monitor, then it is a obvious error.
Are you a board vendor who made this “Holybro” baseboard or you just bought it from somewhere?
Oh I see. I bought it directly from the company through its website .
According to documentation I installed Jetpack using SDK Manager.
Please contact with the board vendor. This hardware is definitely not able to really work with image from sdkmanager.
Sdkamanger is for NV devkit to use and by default NV devkit is using DP mode.
system
Closed
March 26, 2025, 1:08am
12
