jetpack5.0.1DP flash nvme failed,
jetpack5.0.1dp 下jetson NX 刷机到nvme固态上,总是在99%处卡主了,已经试过好多次了,删除重新构建镜像啥的,都不行,错误照片如下,可能是什么原因呢?
15:25:48 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
15:25:48 SUMMARY: File System and OS - target_image: Install completed successfully.
15:26:06 ERROR: Can not find matching device in recovery mode.
15:28:33 ERROR: Flash Jetson Xavier NX - flash: 36137 blocks
15:28:33 ERROR: Flash Jetson Xavier NX - flash: gzip: /home/wangxin/nvidia/nvidia_sdk/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
15:29:45 ERROR: Flash Jetson Xavier NX - flash: 52364 blocks
15:29:46 ERROR: Flash Jetson Xavier NX - flash: 20+0 records in
15:29:46 ERROR: Flash Jetson Xavier NX - flash: 20+0 records out
15:29:46 ERROR: Flash Jetson Xavier NX - flash: 20 bytes copied, 0.000633987 s, 31.5 kB/s
15:46:14 ERROR: Flash Jetson Xavier NX - flash: 131072+0 records in
15:46:14 ERROR: Flash Jetson Xavier NX - flash: 131072+0 records out
15:46:14 ERROR: Flash Jetson Xavier NX - flash: 67108864 bytes (67 MB, 64 MiB) copied, 1.04841 s, 64.0 MB/s
15:46:43 ERROR: Flash Jetson Xavier NX - flash: 36137 blocks
15:46:43 ERROR: Flash Jetson Xavier NX - flash: gzip: /home/wangxin/nvidia/nvidia_sdk/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
15:47:03 ERROR: Flash Jetson Xavier NX - flash: 52364 blocks
15:47:04 ERROR: Flash Jetson Xavier NX - flash: 20+0 records in
15:47:04 ERROR: Flash Jetson Xavier NX - flash: 20+0 records out
15:47:04 ERROR: Flash Jetson Xavier NX - flash: 20 bytes copied, 0.000480422 s, 41.6 kB/s
16:01:37 ERROR: Flash Jetson Xavier NX - flash: 131072+0 records in
16:01:37 ERROR: Flash Jetson Xavier NX - flash: 131072+0 records out
16:01:37 ERROR: Flash Jetson Xavier NX - flash: 67108864 bytes (67 MB, 64 MiB) copied, 1.36752 s, 49.1 MB/s
16:02:19 ERROR: Flash Jetson Xavier NX - flash: tar: Write checkpoint 10000
16:02:25 ERROR: Flash Jetson Xavier NX - flash: tar: Write checkpoint 20000
16:02:27 ERROR: Flash Jetson Xavier NX - flash: tar: Write checkpoint 30000
