Hi everyone,
I am using my custom carried board and use a GPIO to control the PWM signal(low active, the PWM signal is not pulled low now). This GPIO is controlled by a regulator’s gpio terms. It has worked in Jetpack4.6. But when i upgraded JetPack5.1, the regulator seems not to work correctly.
regulator DTS is here
fixed-regulators {
p3509_vdd_fan: regulator@111 {
gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(Q, 6) GPIO_ACTIVE_HIGH>;
enable-active-low;
but when i use cat /sys/kernel/debug/gpio
it always shows out hi ACTIVE LOW, not change status though the PWM is output
So what should i do when updating to JetPack5.1
Thank you.
Best Regards,
Ultwcz1997.
Hi ultwcz1997,
Are you using the devkit or custom board for Xavier NX?
Could you help to verify with JP5.1.1(R35.3.1)?
Have you configured this GPIO as PWM usage through pinmux spreadsheet?
Hi @KevinFFF ,
yes, now it is the latest.
No, i used PQ6 as a normal GPIO to output low or high.
Hi @KevinFFF ,
It used pwm-fan.c in driver/hwmon ,
So what should i do to set the correct DTS settings?
Thank you.
Please use JP5.1.1(R35.3.1) instead of JP5.1(R35.2.1) to verify.
I found the default pin for pwm-fan is GPIO14(PH.01).
Could you verify if it would work w/o any changes in pinmux or device tree?
Hi @KevinFFF
The problem was pwm-fan driver is changed, and now i changed DTS, vdd-fan-supply > fan-supply
pwm-fan {
fan-supply = <&p3509_vdd_fan>;
fixed-regulators {
gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(Q, 6) GPIO_ACTIVE_LOW>;
enable-active-low;
Now GPIOQ6 is changed to LOW when pwm output, but when PWM’s duty is 0, the GPIOQ6 was still LOW, expect HIGH.
I think that the regulator_disable() function does not work.
kayccc
July 12, 2023, 2:17am
8
Sorry for the late response, is this still an issue to support? Thanks
It is resolved because the PWM driver changed in JetPack5.1.1
I’m sorry to forget it.
system
Closed
July 26, 2023, 4:00am
11
