Jetracer Road Following Live Demo Does Nothing
After running through basic motions and the interactive trainer (training 150 images and 20 or so epochs) (both notebooks working) I save it to the path road_following_model.pth, run through the road following notebook and nothing happens. It just drives straight, not adjusting for the track at all. It is almost as if the training is not working and it is just running through basic motions (even though I shut down that notebook). I tested the model live with the blue circle and it is predicting the correct spots, just not doing anything in the road following notebook. I have tried re-training it with new data but I can’t seem to get anything to work. I’m not sure if I am doing something wrong, if it is a hardware issue, or a software issue.
Help would be much appreciated
Thank you
Suggest to get the support for JetRacer from GitHub - NVIDIA-AI-IOT/jetracer: An autonomous AI racecar using NVIDIA Jetson Nano
Thank you for the suggestion. I have posted the issue there.
