Jetson AGX Orin GPIO Pin 18 (PWM5/PWM8) Not Generating PWM Output While Pin 13 Works
I am using a Jetson AGX Orin and trying to generate a PWM signal on physical Pin 18 (PWM5). I enabled PWM5 through Jetson-IO and rebooted the system, but I am unable to observe any PWM output on Pin 18. As a comparison, I configured physical Pin 13 (PWM8) using the same procedure, and PWM generation works correctly on that pin. Could someone help verify whether any additional configuration is required for PWM5 on Pin 18 or if there are known issues with this pin?
Hello @joseph.thomas!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
Hi joseph.thomas,
Could you share the steps how did you generate PWM output after configuring the pinmux through jetosn-io tool?
You can also refer to Unable to generate PWM with Nvidia Jetson AGX Orin Development Kit - #6 by KevinFFF for the steps to verify PWM on AGX Orin.
