I cant generate pwm signal on Jetson Orin NX
The Jetson Orin does not generate any PWM signal directly, even though the PWM pins are enabled.
Are you using 3rd party carrier board or your custom carrier board?
Have you check Jetson Orin NX and Nano Series — NVIDIA Jetson Linux Developer Guide?
