Hi, how can I upgrade the GPU driver on Jetson AGX Orin? I was redirected here from this thread: MapSMtoArchName for SM 8.7 is undefined. Default to use Ampere - #5 by Robert_Crovella
iGPU driver is integrated into the OS so you will need to reflash the system.
How do you setup the device with OS and CUDA?
CUDA 12 can work on JetPack 5 with compat support.
I update the system like this:
apt-get update && apt-get dist-upgrade && apt-get autoremove -y
First, I installed CUDA by running the generic Linux runfile installer. Then I removed it and installed the Jetson-specific CUDA files according to the instructions at https://developer.nvidia.com/cuda-downloads?target_os=Linux&target_arch=aarch64-jetson&Compilation=Native&Distribution=Ubuntu&target_version=22.04&target_type=deb_local
Have you exported the compat folder?
export PATH=/usr/local/cuda-12/bin:${PATH}
export LD_LIBRARY_PATH=/usr/local/cuda-12.4/compat
OK, with this it works. Thanks!
