Upgrade TensorRT and CUDA on AGX Orin without Jetpack 6.0
Is it possible to upgrade TensorRT to 8.6.x and CUDA to 12.x without upgrading JetPack from 5.1.2 to 6.0? Basically I need the newer TensorRT to enable quantization of a specific layer type but Isaac ROS is only supported on JetPack 5.1.2.
I noticed a similar thread but it was on AGX Xavier and I’m not sure if it would be different for AGX Orin.
CUDA 12 can work on the JetPack 5 GPU driver with the compatibility feature.
However, cuDNN and Tensor cannot.
The TensorRT 8.6 packages for L4T only supports Ubuntu 22.04.
