Jetson AGX ORIN PCIE PEX_WAKE_N
In my application, I have two AGX Orin Modules on a PCB, designated as AGX Orin Module #1 and AGX Orin Module #2, along with two NVMe SSDs attached to the two AGX Orin Modules, each AGX Orin Module connects to one NVMe SSD via its own PCIe Controller 4. And, the two AGX Orin Moduless are interconnected through PCIe Root Complex (#1 as RC) and PCIe Endpoint (#2 as EP) interfaces via its own PCIe Controller 5.
Here is how the PEX_WAKE_N pin connected in our application. The Wake_N pin of NVMe SSD1 is connected to the PEX_WAKE_N pin of AGX Orin #1, and the Wake_N pin of NVMe SSD2 is connected to the PEX_WAKE_N pin of AGX Orin #2. As in the design guide, the PEX_WAKE_N pin of AGX Orin #2 (PCIe EP) is connected to the PEX_WAKE_N pin of AGX Orin #1 (PCIe RC). Since the PEX_WAKE_N is a common pin shared by all the PCIes, the two PEX_WAKE_N pins of the two AGX Orin Modules and the two Wake_N pins of the SSDs are tied together as result.
My question is, are above connections for the PEX_WAKE_N correct? How do I connect the PEX_WAKE_N in my application?
Could you please confirm whether either NVMe SSD needs to wake its connected Jetson using the PEX_WAKE signal?
Thank you,
Hello Hiwata,
I am not sure wether the wake signal is the mandatory signal for the SSD interface. But I don’t need the wake signal from SSD, can I remove the wake connection from SSD to ORIN?
If you do not need the SSD wake function, you can leave the SSD’s wake signal unconnected, but as a precaution, please reserve a footprint for a 0Ω resistor in the connection and leave it unpopulated by default.
For connection between the two Orin modules, please use an isolator as shown in the Design Guide.
Thank you,
Hi Hiwada,
Thank you for the support.
A level translator TXB0104 will be used as the isolator.
