Hi Support,
We are developing GMSL camera driver on Jetpack 6.0 (R36.3), and the argus_camera tool does not work. Please help check it, thanks.
- DTS file
modules {
status = "okay";
module0 {
status = "okay";
badge = "cam0_bottomleft";
position = "bottomleft";
orientation = "1";
drivernode0 {
status = "okay";
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
devname = "imx728 30-001b";
/* Declare the device-tree hierarchy to driver instance */
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/i2c@3180000/tca9546@70/i2c@0/cam_0@1b";
- Use the v4l2-ctl command to print the frame rate,it’s OK.
nvidia@nvidia-desktop:~$ v4l2-ctl -d /dev/video0 --stream-mmap
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.00 fps
- When using the argus_camera tool, an error message appears: “No cameras available”.
nvidia@nvidia-desktop:~$ argus_camera -d 0
Executing Argus Sample Application (argus_camera)
Argus Version: 0.99.3.3 (multi-process)
Error generated. /usr/src/jetson_multimedia_api/argus/apps/camera/modules/Dispatcher.cpp, initialize:1025 No cameras available
Error generated. /usr/src/jetson_multimedia_api/argus/apps/camera/modules/Dispatcher.cpp, Dispatcher:978 (propagating)
(NvCameraUtils) Error InvalidState: Mutex already initialized (in Mutex.cpp, function initialize(), line 41)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function open(), line 54)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 262)
(Argus) Error InvalidState: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 106)
Error generated. /usr/src/jetson_multimedia_api/argus/apps/camera/modules/Dispatcher.cpp, initialize:1017 Failed to create CameraProvider
Error generated. /usr/src/jetson_multimedia_api/argus/apps/camera/modules/Dispatcher.cpp, getInstance:1001 Initalization failed
