We want to know the RGMII timings-related specifications such as output skew (for Tx), setup/hold times (for the Rx) and duty cycle specs for Tx/Rx clk for AGX Orin SOM. Can the NVIDIA team share information on the same?
Also, Does the Orin module contain internal termination resistors for Tx signals?
Note: We already did refer to the DG for Orin SOM and we couldn’t find the above information apart from a note that states that Orin doesn’t support RGMII-ID internally and an external delay must be added (via PHY internal delay or PCB).
