Hi NV Support Team,
Will PHY RMII interaces that is connected to RGMII AGX Orin work properly?
Or RGMII the only 1G interface is available?
Thank you in advance!
Please refer to Design Guide: The Orin module provides an RGMII interface to support 1 Gigabit Ethernet functionality. As shown in Figure 8-1 and Figure 8-2, the Ethernet PHY, magnetics and RJ45 connector are not included on Orin module and must be implemented externally to the Orin module.
