ORIN module integrates Ethernet MAC for 10G and RGMII 1000M. And it supports PTP . Can ORIN output PPS signal from PTP controller?which GPIO can support PPS output?
Please refer to below info in DG:
The Orin module provides an RGMII interface to support 1 Gigabit Ethernet functionality. The Ethernet PHY, magnetics and RJ45 connector are not included on Orin module and must be implemented externally to the Orin module.
The Orin module supports one of the four Multi-Gigabit Ethernet (MGBE) interfaces on the Orin SoC: MGBE Controller #0. Communication between the Orin MGBE controller and external devices (for example, Ethernet PHYs and switches) can be achieved by XFI or SFI differential connections, supporting 5 Gbps and 10 Gbps line rates on XFI or SFI lanes.
