Hi, i’m trying to change the OS to RT-Linux without reflashing, but i’m a little lost.
I compiled in native the image, following:
Hi @trueshadow97 , this is the guide updated for JetPack 4.5 (L4T 32.5):
Real-time Linux for Jetson Nano (L4T 32.5)
Install required packages
sudo apt-get update
sudo apt-get install libncurses5-dev
sudo apt-get install build-essential
sudo apt-get install bc
sudo apt-get install lbzip2
sudo apt-get install qemu-user-static
sudo apt-get install python
Create folder
mkdir $HOME/jetson_nano
cd $HOME/jetson_nano
Download required files
L4T Jetson Driver Package:
wget https://developer.nvidia…
This step i skipped because i didnt have any lib/module dir on Linux_for_Tegra/rootfs. But in Linux_for_Tegra/kernel I already have a kernel_supplements.tbz2 file.
Then i read this:
I applied real-time kernel patches on our kernel image using the method described in this thread:
Now I’d like to update our devices that are already at customers and we are not able to reflash the jetsons. Is it possible to apply these changes on a system that was running a non-realtime kernel before?
What do I need to run or replace? I guess replacing only the kernel image “Image”-file is not enough, since modules have been changed, too.
What steps do I need to do?
I am running Je…
But i dont know how to:
Sorry if is an easy question, thanks for the help.
DaveYYY
February 23, 2024, 12:22pm
2
Better read the document first:
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/SD/Kernel/KernelCustomization.html#to-build-the-real-time-kernel
If you are compiling natively, just replace every Linux_for_Tegra/rootfs/ in the document with / on your device.
system
Closed
March 13, 2024, 2:19am
3
