Jetson AGX Orin SDK USB Type-C
Hello All,
I cannot connect from my MacBook to Jetson AGX Orin SDK’s USB type-C, as explained in this page:
(headless configuration + Mac)
I can connect to the SDK using ssh, but my purpose is to connect to Jetson as USB device mode.
Am I missing a step to enable connecting from my MacBook to Jetson AGX Orin SDK USB Type-C Port (10)?
FYI, I can connect using the micro USB.
Thank you very much.
The verified use-case is to connect Orin to a Ubuntu host PC. In this case the Orin can enter device mode and a guidance named L4T-README will pop up on host PC. Please check if you can run this use-case. It may not work properly if connecting to PC in Windows OS or Mac OS.
I see. Thank you very much for your explanation @DaneLLL
