Hi i have a problem with my jetson agx orin connection
I use Jetson AGX Orin Developer Kit
First, i have C-type usb port issue. i know there’s two C-type usb port in agx orin, but both ports don’t work well with my computer.
After update AGX ORIN, My laptop couldn’t read my orin’s c type usb port. So there’s no signal even i enter “lsusb” in my terminal.
=> my micro usb can connect to my laptop. there’s no problem with micro usb
i can’t flash my Orin cause my C-type usb port isn’t detected.
Second, i have DP issue. Only i can see is booting screen(Nvidia green booting screen), after booting screen, there’s no signal. btw orin is still running.
both cable have no problem, i changed my cable, but same problems appear
i will attach my log from micro usb using minicom. the only way i can connect my orin to laptop is using micro usb.
i’m newbie, i want to go home and see my mom. i can’t go home if this problem continue..
$ cat /etc/nv_tegra_release
R34 (release), REVISION: 1.1, GCID: 30414990, BOARD: t186ref, EABI: aarch64, 2
sudo apt update
sudo apt dist-upgrade
sudo reboot
sudo apt install nvidia-jetpack
i already put this code plenty of time. only i know is that code.
orin micro usb reboot log.txt (82.1 KB)
