I tried to update r34.1.1 to r35.4.1
After reboot AGX orin stuck in L4TLauncher on EFI stub: Exiting boot services and installing virtual address map …
I can’t access AGX orin by
ethernet
USB-C
microUSB
keyboard respond in first seconds (numlock), but after stopping of a fan it doesn’t respond
What can I do to reset agx orin?
DaveYYY
November 15, 2023, 1:31am
3
Are you using a DevKit or a custom board?
How did you update it?
There should be serial console log being output from the micro USB cable.
Check /dev/ttyACM0 on your host PC with tools like minicom or picocom.
Hi DaveYYY, it is a devkit.
I modified
/etc/apt/sources.list.d/nvidia-l4t-apt-source.list
and ran
sudo apt update
sudo apt dist-upgrade
sudo reboot
DaveYYY
November 15, 2023, 8:28am
5
Can you please check this?
I tried to connect with microUSB but there was no
/dev/ttyACM*
files created.
DaveYYY
November 15, 2023, 8:34am
7
Yes the device is powered.
LED is white.
I didn’t see a board as a USB device so SDK manager didn’t detect it.
I tried to put device into force-recovery button reset + button force-recovery.
I tried multiple times, and it finally worked only now.
I will try to reflash and return with results.
Yes, I check for dev/tty on host machine connected by both USB-C for flashing and microUsb.
I managed to flash but after rebooting: boot proceeds further, I see IP of my AGX orin in the network.
But it doesn’t boot to OEM process and dev/ttyACM* are not created on a host machine.
I will try to reflash one more time.
If you are sure the IP is there on Orin AGX but micro usb port cannot give you /dev/ttyACM* on your host, then you should check the cable or log on your host.
A IP is only present when you boot into jetson.
If cable does not have data line (cheap power cable), then it won’t be able to dump log.
I reflashed one more time, and this time GUI for OEM was displayed without issues and I was able to proceed with installation.
Yes, I think the problem with MicroUSB was with the cable itself.
system
Closed
November 30, 2023, 12:05am
14
