Jetson AGX Orin boot use USB
hi,I would like to boot Orin via USB, how should I do this? Is there any documentation on this?
Please check UEFI Adaptation — Jetson Linux
Developer Guide 34.1 documentation (nvidia.com)
I use the SDK Manager and select the emmc boot method to burn successfully. But when I choose to use the USB method, it fails. Here is pictures of the problem that i have met.
There is a “EXPORT LOGS” in the picture you just posted.
Export the full log and attach it here. It would be better than sharing screenshot.
here is the export logs.
thanks.
SDKM_logs_JetPack_5.0.2_(rev.1)_Linux_for_Jetson_AGX_Orin_modules_2022-09-19_15-08-11.zip (254.3 KB)
Is this a Orin devkit or custom board?
This is DEVKIT
Could you firstly flash into emmc case and see if your type C usb port is able to run in device mode?
Flashing to usb drive requires the flash port able to work in device mode after boot up.
yes. I have already successful flash into emmc.
So where is the answer of my question here…?
sorry. I am not sure that how to see the type C usb port is able to run in device mode. how to do it.
Please check ifconfig on your jetson and see if there is a interface “l4tbr0” with ip assigned.
I used the ifconfig command to check and the photo below shows an l4tbr0 interface.
Through SDK Manager I used the USB method to burn, the USB will automatically show these partitions as follows, which means orin operated on the USB, but eventually could not burn successfully.
