NVIDIA ORIN AGX Prepare MicroSD Image
I followed the following thread:
When I applied the same I got my emmc image broken. It didn`t boot from both emmc and sdcard.
The following output indicates that mmcblk0 was still tried to be modified instead of only mmcblk1. Can you help me to spot the issue? I would like to prepare .img file to distribute through SDCard.
Regards,
Farabi
mmcblk1p1_sd_card_flash_error.txt (301.8 KB)
I have no idea what you are trying to do.
First, what’s the full command used?
Second, you are just trying to flash to a single SD card, which has nothing to do with creating an SD card image.
Hi @DaveYYY,
Thank you for your reply, as mentioned in my console output, I used the following command which is marked as the answer in the quoted reply.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device mmcblk1p1 -c ./tools/kernel_flash/flash_l4t_external.xml --showlogs --network usb0 jetson-agx-orin-devkit internal
As I couldn`t find a proper document to prepare SD Card, I wanted to check this approach first to test the SDCard operation with ORIN AGX.
Thanks in advance,
Farabi
The command given in the link will actually flash both eMMC and SD card, so it’s expected mmcblk0p1 is also involved, but I’m not sure why you are getting error here.
For validation, flash only eMMC with:
sudo ./flash.sh jetson-agx-orin-devkit internal
flash only SD card with:
-c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml”
–showlogs --network usb0 jetson-agx-orin-devkit internal
Also, can you please try with 35.4.1 instead of 35.3.1?
For generating SD card images, they are stated here:
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/SD/FlashingSupport.html#to-generate-an-image-to-be-flashed-to-an-sd-card
Hi @DaveYYY,
The document you forwarded has a note like given below, and that is why I didn`t applied before:
**Applies to:** Jetson Xavier NX series only
I will give it a try with ORIN AGX with proper board name.
Is there a specific reason you recommended 35.4.1 instead of 35.3.1? I don`t prefer to change my environment if not crucial.
Best Regards,
Farabi
I think the workflow is the same between these two versions, so if you try again and find it working with 35.3.1, then it’s fine and please just keep it.
