Jetson AGX Orin stuck in minimize mode
I tried to upgrade the version of gstreamer on my agx orin, but ran into some problems. I’ve since reverted to the older verson (1.16.3) by building from source.
However my orin is still stuck in minimize mode, and if I try to run sudo unminimize it complains about ubuntu focal Release does not have a Release file.
Any ideas how to fix it? And also is there a good way to revert to the default gstreamer that the Orin ships with?
Please clean the cache for a try:
$ rm ~/.cache/gstreamer-1.0/registry.aarch64.bin
If the issue persists, would suggest re-flash the system to rest the libs to default.
