I’m experiencing difficulties with reflashing my Jetson Orin AGX. After a recent update, the boot sequence became corrupted, resulting in no display output. I am now attempting to reflash the device using a virtual machine running Ubuntu 20.04 on a Windows 11 host. However, the flashing process never completes successfully.
Could you please assist me in resolving this issue? Any guidance on getting the system up and running again would be greatly appreciated.
Thank you for your previous help. I’m encountering a couple of new problems that I could use some assistance with:
GStreamer Issues with OpenCV: After reflashing my Jetson device, I’m having trouble using GStreamer with OpenCV. Here’s the error message I receive when trying to run my script:
[ WARN:0@2.699] global cap_gstreamer.cpp:1728 open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
Additionally, the camera-capture command works perfectly, but my OpenCV code using cv2.VideoCapture(0) does not work as expected.
2. Directory Permissions Problem: I’m also having trouble creating a folder in the detections/data directory of the Jetson Inference project. I need to use sudo to create the folder, but this wasn’t necessary before reflashing the device.
