Hello, simple problem it seems but it is stopping me from flashing to the latest Jetson Linux 35.1. I am following the instructions here:
https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/IN/QuickStart.html#in-quickstart-jetsonmodulesandconfigurations-configurations
But I cannot get the Orin to enter recovery mode. I keep checking from the build host side and see that the Nvidia USB device is 0955:7045 which is not correct per this page:
https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/IN/QuickStart.html#to-determine-whether-the-developer-kit-is-in-force-recovery-mode
I’ve tried holding the recovery button for up to 30 seconds or as little as 1 second and nothing seems to work. The flash.sh script of course fails as its not finding the Orin in recovery mode. What am I missing ?
hello ntheath,
the four-digit number should be 7023 or 7223 for Orin series.
please see-also To Determine Whether the Developer Kit Is in Force Recovery Mode.
may I know what’s your host environment setup, are you using virtual machine?
Thanks @JerryChang, I figured out my problem. The instructions mentioned attaching a USB cable but do not call out the port. I had attached my USB cable to the micro-USB port, but this is incorrect. The micro-USB port is for UART logs only. The correct port is the USB-C port opposite the power USB-C port (other side of the module). After connecting correctly I was able to verify recovery mode and reflash successfully.
this also mentioned in [How-to] session of Jetson AGX Orin Series Developer Kit User Guide .
