I followed the instructions for entering force recovery mode using the buttons on the device but got no results. I also tried entering this mode through the terminal, but it just turned off my device.
Basically, I’m getting the same issue detailed here:
I do not have another AGX Orin to validate this on, but I am quite sure I have followed the correct steps for entering force recovery mode based on the documentation.
I have tried holding down the force recovery button and either pressing the Reset button (if already powered) or the Power button, then releasing both buttons. I have also tried using this command in the terminal:
sudo reboot --force forced-recovery
Does that mean this is a hardware issue, or are there other methods to explore?
I use a Razer Blade 15, which typically has a Windows environment, but I have been running through WSL with Ubuntu. I also installed the SDK Manager through WSL, and the board was not visible there either.
