nvidia-support-192.168.3.209-20260910-172345.tar.gz (3.4 MB)
NVIDIA Jetson kernel issue support bundle
Collected from jetson agx thor (hostname: lzc-pod-rwZVvx) on 2026-09-10, approximately 17:24–17:27 UTC+08:00.
Platform
NVIDIA Jetson AGX Thor
Ubuntu 24.04.4 LTS
Kernel: 6.8.12-1021-tegra, #1 SMP PREEMPT Tue Jul 21 15:58:47 CST 2026
NVIDIA L4T: R39, revision 2.0 (GCID 45755727)
Observed issue
The reports a kernel problem. Exact reproduction steps and the visible application symptoms were not provided.
Collected evidence shows repeated hung-task warnings involving kworker/u28:0, nv_queue, nvidia-modeset and other processes. The current boot includes warnings at 16:54:14 through 17:00:16 (UTC+08:00), with blocked durations up to 483 seconds. The preceding boot also contains hung-task warnings.
Live process stacks show nvidia-smi in uninterruptible D state, waiting in os_acquire_rwlock_read → portSyncRwLockAcquireRead → rmapiLockAcquire inside the NVIDIA kernel module. Several nvidia-smi processes were already blocked before collection. This identifies an observed wait location, not a confirmed root cause.
The kernel logs also contain repeated nvethernet xpcs_write_safety failures. Their relationship to the GPU/kernel blocking is unknown.
I noticed that it says here that similar issues have already been fixed in JetPack7.2, but I am still experiencing similar phenomena in JetPack7.2:
https://forums.developer.nvidia.com/t/jetson-thor-r38-4-jp7-1-devfreq-rmapilockacquire-deadlock-wedges-all-gpu-tasks-in-d-state/372833/6#main-container#1
Files to inspect first
nvidia-bug-report-safe.log.gz: official NVIDIA GPU report, successfully completed with --safe-mode (exit 0).
nvidia-bug-report-jetson.log: official Jetson report with platform details, retained system journal, dmesg and kernel configuration. Collection was interrupted after it invoked the standard GPU report, which blocked in nvidia-smi --version. It therefore lacks its final completion marker.
kernel/highlights.txt: selected warning/error lines with surrounding kernel context, derived from the per-boot logs; originals remain included.
system/blocked-task-stacks.txt: live process list and /proc//stack + status for D-state processes.
kernel/boot-6d6a9d630639478583170ec6bc724422.log.gz: current boot kernel log.
kernel/boot-756ee3b97d034aa8ad059b117ec6b7c3.log.gz: preceding boot kernel log.
system/boots.txt: retained boot IDs and time ranges.
system/journal-boot-0.log.gz and system/journal-boot–1.log.gz: full system journals for the current and preceding boot.
kernel/dmesg-*.txt: current kernel ring buffer, captured before and after collection.
system/packages.txt, kernel-module-details.txt, identity.txt: package, driver and OS versions.
persistent/: available rotated kernel/boot logs and kernel/boot configuration.
collection-status.txt, collection-notes.txt and *console.txt: collection status and limitations.
SHA256SUMS: checksums of all other files in this directory.
Collection limitations
Standard nvidia-smi and nvpmodel read-only queries blocked in kernel waits (os_acquire_rwlock_read and min_freq_show respectively). Their collection process groups were stopped; exit 137 is recorded. D-state tasks may remain until the underlying kernel wait resolves.
The standard GPU report started by the Jetson script also blocked. Its small output is preserved as nvidia-bug-report.partial.log.gz; use the completed safe-mode report for GPU diagnostics.
The boot list has 9 boot IDs. The oldest boot (2026-09-02, ID 0dc45e4d84a840b28157a7f1d2b78c72) has no retained kernel entries; its kernel export contains “-- No entries --”.
An initial parser also treated the boot-list header as an ID, generating an empty boot-BOOT.log.gz. That empty derived file was removed locally; its failed attempt remains in collection-status.txt for transparency.
/sys/fs/pstore and /var/lib/systemd/pstore were empty: no persistent kernel crash dump was available.
/var/crash contained an application crash report for ChatGPT. Only the crash-file listing was collected; that application memory dump is not included.
Some display/PCI queries reported unavailable data; see the official collector console logs.
Remote-to-local archive SHA-256 matched: 59c803be85471ed3e16a707190cf7dfbbae0692884b18b2dd083f18063354053. The final bundle additionally contains this README, derived highlights and checksums.
No reboot, kernel/driver changes or service restart was performed as part of collection.
