After connecting the display, frequent freezing occurs after restarting
We mounted the AGX Thor module on our self-developed carrier board. After powering on the system, clicking the restart button on the display interface to reboot resulted in a freeze (such as a black screen or no response) about 3 out of 5 times.
The system version is as follows
nvidia@nvidia:~$ uname -r
6.8.12-rt-tegra
nvidia@nvidia:~$ uname -a
Linux nvidia 6.8.12-rt-tegra #1 SMP Mon Feb 2 11:32:24 CST 2026 aarch64 aarch64 aarch64 GNU/Linux
nvidia@nvidia:~$ cat /etc/nv_tegra_release
R38 (release), REVISION: 4.0, GCID: 43443517, BOARD: generic, EABI: aarch64, DATE: Wed Dec 31 00:15:19 UTC 2025
KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
INSTALL_TYPE=openrm
The log is as follows
The first time I pressed the restart button and entered the password, the screen went white. Three minutes later, the system restarted and entered the system.
[   12.494384] printk: legacy console [ramoops-1] enabled
[   12.496827] dce: dce_ipc_channel_init_unlocked:248  Invalid Channel State [0x0] for ch_type [2]
[   12.498343] pstore: Registered ramoops as persistent store backend
[   12.498345] ramoops: using 0x200000@0x1fbf880000, ecc: 0
[   12.526071] dce: dce_admin_send_cmd_ver:825  version : dcefw:[0x4] dcekmd:[0x4] err : [0x0]
[   12.534742] dce: dce_admin_setup_clients_ipc:1004 Channel Reset Complete for Type [1] ...
[   12.542638] dce: dce_admin_setup_clients_ipc:980  Get queue info failed for [2]
[ ÿè[TS:ÿá  12ÿè3185ÿá.550ÿè5203ÿá428]ÿè040]ÿá dceÿèStarÿá: dcÿètingÿáe_adÿè RmBÿámin_ÿèootsÿásetuÿètrapÿáp_clÿè
[TÿáientÿèS:31ÿás_ipÿè8552ÿác:10ÿè2463ÿá04 Cÿè2]Reÿáhannÿègistÿáel Rÿèeredÿáesetÿè eveÿá Comÿènt_tÿápletÿèype:ÿáe foÿè[0] ÿár Tyÿèfor ÿápe [ÿèdce_ÿá3] .ÿècoreÿá..
ÿè_ipcÿá[   ÿè_typÿá12.5ÿèe:[1ÿá6009ÿè]
[ÿá2] dÿèTS:3ÿáce: ÿè1855ÿádce_ÿè2492ÿástarÿè34]Rÿát_boÿèegisÿáot_fÿètereÿálow:ÿèd evÿá188 ÿèent_ÿá DCEÿètypeÿá_BOOÿè:[1]ÿáT_DOÿè forÿáNE
ÿè dceÿá[   ÿè_corÿá12.5ÿèe_ipÿá6061ÿèc_tyÿá0] tÿèpe:[ÿáhermÿè3]
ÿáal-tÿè[TS:ÿárip-ÿè3185ÿáevenÿè5269ÿát gpÿè651]ÿáu-thÿèdce_ÿárottÿèipc ÿále-aÿèStatÿálertÿèe Inÿá: coÿèitiaÿáolinÿèlizeÿág deÿèd
[ÿáviceÿèTS:3ÿá regÿè1855ÿáisteÿè3025ÿáred.ÿè49]Rÿá
[ ÿèmBooÿá  12ÿètstrÿá.589ÿèap cÿá505]ÿèomplÿá tegÿèetedÿára-bÿè sucÿápmp-ÿècessÿábwmgÿèfullÿár bwÿèy
ÿámgr: set EMC floor frequency to 665600KHz
[   12.613957] thermal-trip-event soc012-throttle-alert: cooling device registered.
[   12.638176] nvpps c230000.nvpps: nvpps_probe
[   12.638560] nvpps c230000.nvpps: primary-emac : ethernet@a808a10000
[   12.642227] nvpps c230000.nvpps: ts-capture-interval set to 1000msce registered.
[   12.656747] nvpps c230000.nvpps: PPS GPIO not provided in DT, only Timer mode available
[   12.671535]  cs_system_cfg: CoreSight Configuration manager initialisedER
[   12.671610] arm_spe_pmu spe-pmu: probed SPEv1.2 for CPUs 0-13 [max_record_sz 64, align 64, features 0x57]
[   12.671744] nvpps nvpps0: Using Lock threshold value(in ns) : 20000
[   12.671758] nvpps c230000.nvpps: tsc_res_ns(1)
[   12.704478] ivc-cdev: hypervisor not present
[   12.710248] tegra194-isp5 8188800000.isp: Adding to iommu group 52
[   12.715126] nvsciipc nvsciipc: creating nvsciipc_uid sysfs group
[   12.718170] driver not enabled, cannot register any devices
[   12.718714] nvsciipc nvsciipc: nvsciipc_uid sysfs group: done
[   12.732142] irq: IRQ288: trimming hierarchy from :bus@0:pmc@c800000
[   12.732177] nvsciipc: loaded module
[   12.736536] lm90 5-004c: supply vcc not found, using dummy regulator
[   12.746341] nvvrs_pseq 5-003c: NVVRS Vendor ID: 0x98a800000: Adding to iommu group 53
[   12.761523] camrtc-coe tegra-capture-coe0: nvidia,eth_controller[0] node has no device
[   12.761655] nvvrs_pseq 5-003c: NVVRS Model Rev: 0x86
[   12.767772] hwmon hwmon3: temp1_input not attached to any thermal zone-2
[   12.767803] hwmon hwmon3: temp2_input not attached to any thermal zone
[   12.772142] driver not enabled, cannot register any devices
[   12.778475] camrtc-coe tegra-capture-coe1: nvidia,eth_controller[0] node has no device
[   12.787028] nvmap_heap_init: nvmap_heap_init: created heap block cache
[   12.791687] camrtc-coe: probe of tegra-capture-coe1 failed with error -2
[   12.792688] camrtc-coe tegra-capture-coe2: nvidia,eth_controller[0] node has no device
[   12.799837] nvmap_co_device_init: vpr :dma coherent mem declare 0x0000002004600000,914358272
[   12.802515] camrtc-coe: probe of tegra-capture-coe2 failed with error -2
[   12.806192] camrtc-coe tegra-capture-coe3: nvidia,eth_controller[0] node has no device
[   12.810548] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[   12.817182] camrtc-coe: probe of tegra-capture-coe3 failed with error -2
[   12.855211] spi-tegra114 c6c0000.spi: Adding to iommu group 54
[   12.855336] nvmap_page_pool_init: Total RAM pages: 32197969
[   12.855561] at24 1-0050: supply vcc not found, using dummy regulator
[   12.856484] at24 1-0050: 256 byte 24c02 EEPROM, read-only
[   12.876209] CAN device driver interface
[   12.876954] spi-tegra114 810c590000.spi: Adding to iommu group 55
[   12.881092] nvmap_page_pool_init: nvmap page pool size: 4024746 pages (3433 MB)
[   12.881893] spi-tegra114 810c440000.spi: Adding to iommu group 56
[   12.886734] spi-tegra114 810c450000.spi: Adding to iommu group 57
[   12.894148] irq: IRQ295: trimming hierarchy from :bus@0:pmc@c800000
[   12.897760] nvmap_background_zero_thread: PP zeroing thread starting.00 size (892928KiB)
[   12.903484] rt5640 7-001c: Device with ID register 0x0 is not rt5640/39
[   12.910098] nvmap_heap_create: fsi :dma coherent mem declare 0x0000001fc4000000,16777216
[   12.942702] TT CAN feature is not supported
[   12.943256] nvmap_heap_create: created heap fsi base 0x0000001fc4000000 size (16384KiB)
[   12.949901]   Message RAM Configuration
[  12.949901]   | base addr   |0x81102f2000|
   12.949901]   | sidfc_flssa |0x00000000|
[  12.949901]   | xidfc_flesa |0x00000040|
[   12.949901]  | rxf1c_f1sa  |0x000009c0|
   12.949901]   | rxbc_rbsa   |0x000009c0|
[  12.949901]   | txefc_efsa  |0x000009c0|
[   12.949901]  | tmc_tmsa    |0x00000ec0|
   12.949901]   | mram size   |0x00001000|
[   12.968386] cloud-init[430]: Cloud-init v. 25.2-0ubuntu1~24.04.1 running 'init' at Fri, 11 Jul 2025 18:53:[   13.023551] Release 3.2.3 from 09.06.2018
[   13.026846] net can0: mttcan device registered (regs=0000000000b7c835, irq=296)
[   13.031171] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/arad@9870000
[   13.050977] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/processing-engine@9780000
[   13.063383] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/asrc@9850000
[   13.075277] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amixer@9820000
[   13.075283] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95d0000
[   13.075285] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95c0000
[   13.075289] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95b0000
[   13.075292] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95a0000
[   13.075294] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@9590000
[   13.075297] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9560000
[   13.075299] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9550000
[   13.075301] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9540000
[   13.075304] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9530000
[   13.075306] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9520000
[   13.075308] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9510000
[   13.075311] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/mvc@9810000
[   13.075313] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/mvc@9800000
[   13.075315] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9730000
[   13.075317] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9720000
[   13.075319] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9710000
[   13.075322] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9700000
[   13.075326] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000
[   13.075328] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@9280000
[   13.075331] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/admaif@9610000
[   13.088314] tegra23x-psc e860000.psc: Adding to iommu group 59Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.098333] /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000: Fixed dependency cycle(s) with /bus@0/i2c@810c680000/audio-codec@1c
[   13.111588] tegra23x-psc e860000.psc: init done
[   13.113209] igb 0003:04:00.0 enP3p4s0: renamed from eth1
[   13.223674] usbcore: registered new device driver onboard-usb-hubed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.227204] /bus@0/aconnect@9000000/ahub@9630000/amx@9510000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.407505] /bus@0/aconnect@9000000/ahub@9630000/amx@9520000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.407512] /bus@0/aconnect@9000000/ahub@9630000/amx@9530000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.407517] /bus@0/aconnect@9000000/ahub@9630000/amx@9540000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.407522] /bus@0/aconnect@9000000/ahub@9630000/amx@9550000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.407527] /bus@0/aconnect@9000000/ahub@9630000/amx@9560000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.407533] /bus@0/aconnect@9000000/ahub@9630000/adx@9590000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.407538] /bus@0/aconnect@9000000/ahub@9630000/adx@95a0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.407543] /bus@0/aconnect@9000000/ahub@9630000/adx@95b0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.407548] /bus@0/aconnect@9000000/ahub@9630000/adx@95c0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.407552] /bus@0/aconnect@9000000/ahub@9630000/adx@95d0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.407557] /bus@0/aconnect@9000000/ahub@9630000/adx@95e0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.407562] /bus@0/aconnect@9000000/ahub@9630000/admaif@9610000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.407624] /bus@0/aconnect@9000000/ahub@9630000/sfc@9710000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.570456] /bus@0/aconnect@9000000/ahub@9630000/sfc@9720000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.570460] /bus@0/aconnect@9000000/ahub@9630000/sfc@9730000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.570464] /bus@0/aconnect@9000000/ahub@9630000/processing-engine@9780000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.570469] /bus@0/aconnect@9000000/ahub@9630000/mvc@9800000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.570473] /bus@0/aconnect@9000000/ahub@9630000/mvc@9810000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.570478] /bus@0/aconnect@9000000/ahub@9630000/amixer@9820000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.570484] /bus@0/aconnect@9000000/ahub@9630000/asrc@9850000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
01[   13.570490] /bus@0/aconnect@9000000/ahub@9630000/arad@9870000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   13.570640] TT CAN feature is not supported
[   13.570647]   Message RAM Configuration
[  13.570647]   | base addr   |0x8110302000|
[   13.570647]  | sidfc_flssa |0x00000000|
   13.570647]   | xidfc_flesa |0x00000040|
[  13.570647]   | rxf0c_f0sa  |0x000000c0|
[   13.570647]  | rxbc_rbsa   |0x000009c0|
   13.570647]   | txefc_efsa  |0x000009c0|
[  13.570647]   | txbc_tbsa   |0x00000a40|
[   13.570647]  | mram size   |0x00001000|
[   13.571228] usb 1-4.4: USB disconnect, device number 3
[   13.572109] tegra-aocluster bus@0:aocluster@c000000: Tegra AOCLUSTER bus registered
[   13.585274] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[   13.594981] ina238 2-0044: error configuring the device: -121
[   13.607102] xhci_hcd 0001:01:00.0: Adding to iommu group 60
[   13.610566] net can1: mttcan device registered (regs=000000007518e9ca, irq=306)0:05:56 UTC (356)
[   13.6132ÿäVM 8ÿá78] ÿä001:ÿáinpuÿä I/Tÿát: NÿäC: WÿáVIDIÿäARNIÿáA JeÿäNG (ÿátsonÿäinseÿá Thoÿäcureÿár AGÿä conÿáX HDÿäfiguÿáA HDÿäratiÿáMI/Dÿäon):ÿáP,pcÿä Faiÿám=3 ÿäled ÿáas /ÿäto gÿádeviÿäet mÿáces/ÿäonotÿáplatÿäonicÿáformÿä couÿá/busÿänterÿá@0/8ÿä forÿá8090ÿä REEÿáb000ÿä FS,ÿá0.hdÿä usiÿáa/soÿäng 0ÿáund/ÿä
[   13.783981] T Message RAM Configurationrted
   13.783981]   | base addr   |0x8110332000|
[  13.783981]   | sidfc_flssa |0x00000000|
[   13.783981]  | rxf0c_f0sa  |0x000000c0|
   13.783981]   | rxf1c_f1sa  |0x000009c0|
[  13.783981]   | rxbc_rbsa   |0x000009c0|
[   13.783981]  | txbc_tbsa   |0x00000a40|
   13.783981]   | tmc_tmsa    |0x00000ec0|
[  13.783981]   | mram size   |0x00001000|
[   13.787061] Release 3.2.3 from 09.06.2018
 +0000. Up 12.60 seconds.
[   13.011576] cloud-init[430]: ci-info: +++++++++++++++++++++++++++Net device info++++++++++++++++++++++++++++
[   13.860999] cloud-init[430]: ci-info: +--------+-------+-----------+-----------+-------+-------------------+
[   13.884334] cloud-init[430]: ci-info: | Device |   Up  |  Address  |    Mask   | Scope |     Hw-Address    |
[   13.896332] cloud-init[430]: ci-info: +--------+-------+-----------+-----------+-------+-------------------+
[   13.908329] cloud-init[430]: ci-info: |  eth0  | False |     .     |     .     |   .   | 00:a0:c9:00:00:0a |
[   13.920329] cloud-init[430]: ci-info: |  eth1  | False |     .     |     .     |   .   | 00:a0:c9:00:00:0b |
[   13.932310] cloud-init[430]: ci-info: |  eth2  | False |     .     |     .     |   .   | 00:a0:c9:00:00:0c |
[   13.944317] cloud-init[430]: ci-info: |  eth3  | False |     .     |     .     |   .   | 00:a0:c9:00:00:0d |
[   13.956307] cloud-init[430]: ci-info: |   lo   |  True | 127.0.0.1 | 255.0.0.0 |  host |         .         |
[   13.968320] cloud-init[430]: ci-info: |   lo   |  True |  ::1/128  |     .     |  host |         .         |
[   13.980379] cloud-init[430]: ci-info: +--------+-------+-----------+-----------+-------+-------------------+
[   13.992328] cloud-init[430]: ci-info: +++++++++++++++++++Route IPv6 info+++++++++++++++++++
[   14.004320] cloud-init[430]: ci-info: +-------+-------------+---------+-----------+-------+
[   14.016302] cloud-init[430]: ci-info: | Route | Destination | Gateway | Interface | Flags |
[   14.028306] cloud-init[430]: ci-info: +-------+-------------+---------+-----------+-------+
[   14.040322] cloud-init[430]: ci-info: +-------+-------------+---------+-----------+-------+
[   14.062197] systemd-journald[287]: Time jumped backwards, rotating.
[   14.817022] xhci_hcd 0001:01:00.0: xHCI Host Controller
[   14.817163] nvadsp c040000.aon: Adding to iommu group 61
[   14.817273] xhci_hcd 0001:01:00.0: new USB bus registered, assigned bus number 3
[   14.821186] gic 9961000.interrupt-controller: GIC IRQ controller registeredfault
[   14.825877] nvadsp c040000.aon: nvadsp_app_module_probea ACONNECT bus registered
ÿäVM 8001: I/TC: WARNING (insecure configuration): Failed to commit dirh counter 81
ÿá[   14.985163] xhci_hcd 0001:01:00.0: hcc params 0x014051cf hci version 0x100 quirks 0x0000001100000010
[   14.985961] xhci_hcd 0001:01:00.0: xHCI Host Controller
[   14.986190] xhci_hcd 0001:01:00.0: new USB bus registered, assigned bus number 4
[   14.993343] xhci_hcd 0001:01:00.0: Host supports USB 3.0 SuperSpeed
[   15.000545] hub 3-0:1.0: USB hub foundg to iommu group 62
[   15.004779] nvadsp 9d60000.adsp: in probe()...adsp
[   15.005244] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@9280000
[   15.005278] /bus@0/aconnect@9000000/ahub@9630000/i2s@9280000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.006484] /bus@0/i2c@810c680000/audio-codec@1c: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000
[   15.006516] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000
[   15.006528] /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000: Fixed dependency cycle(s) with /bus@0/i2c@810c680000/audio-codec@1c
[   15.006544] /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.007877] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9510000
[   15.007907] /bus@0/aconnect@9000000/ahub@9630000/amx@9510000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.008193] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9520000
[   15.008215] /bus@0/aconnect@9000000/ahub@9630000/amx@9520000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[   15.008504] hub 3-0:1.0: 4 ports detected
[   15.010793] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9530000
[   15.148001] nvadsp 9d60000.adsp: nvadsp_app_module_probe
[   15.150803] tegra-adma 9440000.dma-controller: Tegra210 ADMA driver registered 64 channelsth /bus@0/aconnect@9000000/ahub@9630000
[   15.171892] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[   15.180565] nvadsp 9d60000.adsp1: Adding to iommu group 63
[   15.296276] audit: type=1400 audit(358.184:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=656 comm="apparmor_parser"
[   15.311256] audit: type=1400 audit(358.184:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=655 comm="apparmor_parser"
[   15.311260] audit: type=1400 audit(358.184:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=658 comm="apparmor_parser"ser"
[   15.311261] audit: type=1400 audit(358.184:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=654 comm="apparmor_parser"
[   15.311265] audit: type=1400 audit(358.192:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=661 comm="apparmor_parser"er"
[   15.311267] audit: type=1400 audit(358.192:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-checkns" pid=662 comm="apparmor_parser"
[   15.497390] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   15.498772] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   15.499737] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   15.641840]
[   17.205297] iommu smmu3.0x0000008806000000: IOMMU driver was not able to establish FW requested direct mapping.
ÿçINFO: END TASK:MB
INFO: enter idle task.
INFO: END TASK:MB
ÿá[   18.272528] nvidia 0000:01:00.0: [drm] No compatible format found
[   18.489669] nvidia-modeset: WARNING: HW supports 8 heads. Limiting to 4 heads
[   18.491353] nvidia-modeset: WARNING: GPU:0: The head configuration (0xff) is inconsistent with the number of heads (4)
[   19.323645] cloud-init[1789]: Cloud-init v. 25.2-0ubuntu1~24.04.1 running 'modules:config' at Fri, 11 Jul 2025 18:53:02 +0000. Up 19.28 seconds.
ÿçINFO: END TASK:MB
INFO: END TASK:MB
ÿá
Ubuntu 24.04.3 LTS nvidia ttyUTC0
nvidia login: [   27.438869] platform sound: deferred probe pending: tegra-audio-graph-card: parse error
ÿçINFO: END TASK:MB
INFO: END TASK:MB
ÿá
nvidia login: [   56.281847] rcu: INFO: rcu_sched self-detected stall on CPU
[   56.281852] rcu:     0-....: (5250 ticks this GP) idle=76e4/1/0x4000000000000000 softirq=2527/2527 fqs=2265
    56.281855] rcu:     (t=5250 jiffies g=2877 q=2026 ncpus=14)
nvidia login:
nvidia login: nvidia
[   68.586062] rcu: INFO: rcu_sched detected expedited stalls on CPUs/tasks: { 0-.... } 5291 jiffies s: 1085 root: 0x1/.
[   68.586068] rcu: blocking rcu_node structures (internal RCU debug):
[   68.586074] NMI backtrace for cpu 0
The screen goes black after entering the password and pressing restart the second time。
[ 12.241068] rt5640 7-001c: Device with ID register 0x0 is not rt5640/39
[ 12.255081] [drm] Initialized tegra 1.0.99 20120330 for 8181200000.host1x.drm on minor 1
[ 12.448806] cs_system_cfg: CoreSight Configuration manager initialised
[ 12.578018] Host1x-Fence: Default interface init done
[ 12.989973] TT CAN feature is not supportedg to iommu group 41
[ 12.990035] spi-tegra114 810c450000.spi: Adding to iommu group 42
[ 12.991761] Message RAM Configuration
[ 12.991761] | base addr |0x81102f2000|
[ 12.991761] | sidfc_flssa |0x00000000|
[ 12.991761] | rxf0c_f0sa |0x000000c0|
12.991761] | rxf1c_f1sa |0x000009c0|
[ 12.991761] | rxbc_rbsa |0x000009c0|
[ 12.991761] | txbc_tbsa |0x00000a40|
12.991761] | tmc_tmsa |0x00000ec0|
[ 12.991761] | mram size |0x00001000|
[ 13.045147] Release 3.2.3 from 09.06.2018
[ 13.045500] net can0: mttcan device registered (regs=000000007d9406e4, irq=294)
[ 13.052202] tegra23x-psc e860000.psc: Adding to iommu group 43
[ 13.052428] tegra23x-psc e860000.psc: init done
[ 13.056927] xhci_hcd 0001:01:00.0: Adding to iommu group 44device registered.
[ 13.058017] scare-pigeon 8188700000.vi0-thi: capture_support_probe: hwpm VI address: 0x8188700000
[ 13.061672] arm_spe_pmu spe-pmu: probed SPEv1.2 for CPUs 0-13 [max_record_sz 64, align 64, features 0x57]
[ 13.073863] nvsciipc nvsciipc: nvsciipc_uid sysfs group: done 45
[ 13.080342] scare-pigeon 8188f00000.vi1-thi: capture_support_probe: hwpm VI address: 0x8188f00000
[ 13.081965] TT CAN feature is not supported
[ 13.081972] Message RAM Configuration
[ 13.081972] | base addr |0x8110302000|
[ 13.081972] | xidfc_flesa |0x00000040|
13.081972] | rxf0c_f0sa |0x000000c0|
[ 13.081972] | rxf1c_f1sa |0x000009c0|
[ 13.081972] | txefc_efsa |0x000009c0|
13.081972] | txbc_tbsa |0x00000a40|
[ 13.081972] | tmc_tmsa |0x00000ec0|
[ 13.081998] thermal-trip-event gpu-throttle-alert: cooling device registered.
[ 13.082008] tegra-bpmp-bwmgr bwmgr: set EMC floor frequency to 665600KHz
[ 13.082287] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx0: Adding to iommu group 46
[ 13.083255] thermal-trip-event soc012-throttle-alert: cooling device registered.
[ 13.085045] Release 3.2.3 from 09.06.2018
[ 13.085949] thermal-trip-event soc345-throttle-alert: cooling device registered.
[ 13.087612] net can1: mttcan device registered (regs=00000000193a1139, irq=308)
[ 13.089215] TT CAN feature is not supported
[ 13.089388] input: NVIDIA Jetson Thor AGX HDA HDMI/DP,pcm=3 as /devices/platform/bus@0/88090b0000.hda/sound/card0/input7
[ 13.098752] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx0: initialized (streamid=4354)
[ 13.104222] Message RAM Configuration
[ 13.104222] | base addr |0x8110332000|
13.104222] | sidfc_flssa |0x00000000|
[ 13.104222] | xidfc_flesa |0x00000040|
[ 13.104222] | rxf1c_f1sa |0x000009c0|
[ 13.104222] | rxbc_rbsa |0x000009c0|
13.104222] | txefc_efsa |0x000009c0|
[ 13.104222] | txbc_tbsa |0x00000a40|
[ 13.104222] | mram size |0x00001000|
[ 13.106485] nvsciipc: loaded module
[ 13.106751] scare-pigeon 8188b00000.isp-thi: capture_support_probe: hwpm ISP address: 0x8188b00000
[ 13.106819] scare-pigeon 818ab00000.isp1-thi: capture_support_probe: hwpm ISP address: 0x818ab00000
[ 13.109088] tegra-se 8188120000.crypto: Adding to iommu group 47
[ 13.110159] tegra-se 8188140000.crypto: registered HASH algorithms
[ 13.110572] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx1: Adding to iommu group 49
[ 13.110623] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx1: initialized (streamid=4355)
[ 13.121969] Release 3.2.3 from 09.06.2018
[ 13.125997] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx2: Adding to iommu group 50
[ 13.165181] net can2: mttcan device registered (regs=000000009fef7a79, irq=309)
[ 13.174110] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 13.194969] TT CAN feature is not supported
[ 13.200383] nvmap_co_device_init: vpr :dma coherent mem declare 0x0000002004600000,914358272
[ 13.205846] Message RAM Configuration
[ 13.205846] | sidfc_flssa |0x00000000|0|
13.205846] | xidfc_flesa |0x00000040|
[ 13.205846] | rxf0c_f0sa |0x000000c0|
[ 13.205846] | rxbc_rbsa |0x000009c0|
13.205846] | txefc_efsa |0x000009c0|
[ 13.205846] | txbc_tbsa |0x00000a40|
[ 13.205846] | tmc_tmsa |0x00000ec0|
[ 13.213176] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 13.220436] Release 3.2.3 from 09.06.2018
[ 13.228197] nvmap_page_pool_init: Total RAM pages: 32197970
[ 13.238929] net can3: mttcan device registered (regs=000000006fde1d43, irq=310)
[ 13.278482] nvmap_page_pool_init: nvmap page pool size: 4024746 pages (3433 MB)
[ 13.278989] nvmap_heap_create: created heap vpr base 0x0000002004600000 size (892928KiB)
[ 13.342545] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0tarting.
[ 13.347653] nvmap_heap_create: fsi :dma coherent mem declare 0x0000001fc4000000,16777216
[ 13.357086] nvvrs-pseq-rtc nvvrs-pseq-rtc: setting system clock to 1970-01-01T00:10:36 UTC (636)
[ 13.361599] nvmap_heap_create: created heap fsi base 0x0000001fc4000000 size (16384KiB)
[ 14.078512] xhci_hcd 0001:01:00.0: xHCI Host Controller
[ 14.078831] xhci_hcd 0001:01:00.0: new USB bus registered, assigned bus number 3
[ 14.078897] nvadsp c040000.aon: Adding to iommu group 51
[ 14.084050] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx2: initialized (streamid=4356)
[ 14.084151] nvadsp c040000.aon: in probe()…aon
[ 14.084900] driver not enabled, cannot register any devices
[ 14.087248] nvadsp c040000.aon: nvadsp_app_module_probe
[ 14.099086] tegra-adma 9440000.dma-controller: Tegra210 ADMA driver registered 64 channels
[ 14.242363] xhci_hcd 0001:01:00.0: hcc params 0x014051cf hci version 0x100 quirks 0x0000001100000010
[ 14.243209] xhci_hcd 0001:01:00.0: xHCI Host Controller
[ 14.243506] xhci_hcd 0001:01:00.0: new USB bus registered, assigned bus number 4
[ 14.250344] xhci_hcd 0001:01:00.0: Host supports USB 3.0 SuperSpeed
[ 14.257382] tegra194-vi5 8181200000.host1x:vi0@8188400000: Adding to iommu group 52
[ 14.257618] hub 3-0:1.0: USB hub found
[ 14.264437] camrtc-coe tegra-capture-coe0: nvidia,eth_controller[0] node has no device
[ 14.266358] driver not enabled, cannot register any devicesvi5_probe: client init done
[ 14.266359] tegra194-vi5 8181200000.host1x:vi0@8188400000: Unable to create debugfs entry
[ 14.267922] hub 3-0:1.0: 4 ports detected
[ 14.268040] tegra-camrtc-capture-isp tegra-capture-isp: capture_isp_probe: Probe-time fuse cache initialized - mask=0x3, num_devices=2
[ 14.275906] camrtc-coe: probe of tegra-capture-coe0 failed with error -2
[ 14.321639] tegra194-vi5 8181200000.host1x:vi1@8188c00000: Adding to iommu group 53
[ 14.328091] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@9280000
[ 14.347912] /bus@0/aconnect@9000000/ahub@9630000/i2s@9280000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.348060] nvadsp 9d60000.adsp: Adding to iommu group 54
[ 14.348209] nvadsp 9d60000.adsp: in probe()…adsp
[ 14.348421] nvadsp 9d60000.adsp: nvadsp_app_module_probe
[ 14.348516] camrtc-coe tegra-capture-coe1: nvidia,eth_controller[0] node has no device
[ 14.348520] camrtc-coe: probe of tegra-capture-coe1 failed with error -2
[ 14.355543] driver not enabled, cannot register any devices
[ 14.368165] hub 4-0:1.0: USB hub found
[ 14.373663] tegra194-isp5 8188800000.isp: Adding to iommu group 55to create debugfs entry
[ 14.383033] camrtc-coe tegra-capture-coe2: nvidia,eth_controller[0] node has no device
[ 14.383227] nvadsp 9d60000.adsp1: Adding to iommu group 56
[ 14.383310] nvadsp 9d60000.adsp1: in probe()…adsp1
[ 14.383343] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx3: Adding to iommu group 57
[ 14.383398] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx3: initialized (streamid=4357)
[ 14.383505] /bus@0/i2c@810c680000/audio-codec@1c: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000
[ 14.383541] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000
[ 14.383555] /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000: Fixed dependency cycle(s) with /bus@0/i2c@810c680000/audio-codec@1c
[ 14.383573] /bus@0/aconnect@9000000/ahub@9630000/i2s@92b0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.383849] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx4: Adding to iommu group 58
[ 14.384180] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx5: Adding to iommu group 5958)
[ 14.384214] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx5: initialized (streamid=4359)
[ 14.384439] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx6: Adding to iommu group 60
[ 14.384472] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx6: initialized (streamid=4360)
[ 14.384674] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx7: Adding to iommu group 61
[ 14.384891] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx8: Adding to iommu group 6261)
[ 14.384925] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx8: initialized (streamid=4353)
[ 14.394714] driver not enabled, cannot register any devices
[ 14.406134] tegra194-isp5 8181200000.host1x:isp1@818a800000: Adding to iommu group 630000 size 10000
[ 14.406885] pva_iommu_context_dev 818c000000.pva0:pva0_niso1_ctx8: PVA syncpt (RO & RW) iova: 78000000, size: 4000000
[ 14.415088] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9510000
[ 14.417633] driver not enabled, cannot register any deviceswith error -2 has no device
[ 14.421324] Allocated pva->fw_carveout
[ 14.433068] pva_kmd 818c000000.pva0: PVA probe completed successfullyependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.440448] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9520000
[ 14.709792] /bus@0/aconnect@9000000/ahub@9630000/amx@9520000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.710099] nvpva_init completed: 0. GSC boot: 1
[ 14.710484] /bus@0/aconnect@9000000/ahub@9630000/amx@9530000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.711252] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9540000
[ 14.711282] /bus@0/aconnect@9000000/ahub@9630000/amx@9540000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.712028] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9550000
[ 14.712056] /bus@0/aconnect@9000000/ahub@9630000/amx@9550000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.712779] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/amx@9560000
[ 14.712808] /bus@0/aconnect@9000000/ahub@9630000/amx@9560000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.713576] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@9590000
[ 14.713605] /bus@0/aconnect@9000000/ahub@9630000/adx@9590000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.714003] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95a0000
[ 14.714020] /bus@0/aconnect@9000000/ahub@9630000/adx@95a0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.714235] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95b0000
[ 14.714248] /bus@0/aconnect@9000000/ahub@9630000/adx@95b0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.714438] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95c0000
[ 14.714450] /bus@0/aconnect@9000000/ahub@9630000/adx@95c0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.714638] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95d0000
[ 14.919018] /bus@0/aconnect@9000000/ahub@9630000/adx@95d0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.919344] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/adx@95e0000
[ 14.942017] /bus@0/aconnect@9000000/ahub@9630000/adx@95e0000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.942312] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/admaif@9610000
[ 14.965766] /bus@0/aconnect@9000000/ahub@9630000/admaif@9610000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.966238] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9700000
[ 14.989556] /bus@0/aconnect@9000000/ahub@9630000/sfc@9700000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 14.989865] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9710000
[ 15.012959] /bus@0/aconnect@9000000/ahub@9630000/sfc@9710000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 15.013277] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9720000
[ 15.036340] /bus@0/aconnect@9000000/ahub@9630000/sfc@9720000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 15.036633] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/sfc@9730000
[ 15.059732] /bus@0/aconnect@9000000/ahub@9630000/sfc@9730000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 15.060025] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/processing-engine@9780000
[ 15.084205] /bus@0/aconnect@9000000/ahub@9630000/processing-engine@9780000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 15.084526] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/mvc@9800000
[ 15.109073] /bus@0/aconnect@9000000/ahub@9630000/mvc@9800000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 15.109367] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/mvc@9810000
[ 15.132442] /bus@0/aconnect@9000000/ahub@9630000/mvc@9810000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 15.167575] /bus@0/aconnect@9000000/ahub@9630000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000/asrc@985000000
[ 15.179164] /bus@0/aconnect@9000000/ahub@9630000/asrc@9850000: Fixed dependency cycle(s) with /bus@0/aconnect@9000000/ahub@9630000
[ 15.202562] /bus@ÿäVM 8ÿá0/acÿä001:ÿáonneÿä I/Tÿáct@9ÿäC: Wÿá0000ÿäARNIÿá00/aÿäNG (ÿáhub@ÿäinseÿá9630ÿäcureÿá000/ÿä conÿáaradÿäfiguÿá@987ÿäratiÿá0000ÿäon):ÿá: Fiÿä Faiÿáxed ÿäled ÿádepeÿäto gÿándenÿäet mÿácy cÿäonotÿáycleÿäonicÿá(s) ÿä couÿáwithÿänterÿá /buÿä forÿás@0/ÿä REEÿáaconÿä FS,ÿánectÿä usiÿá@900ÿäng 0ÿá0000ÿä
ÿá/ahub@9630000
[ 15.325162] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 15.326686] Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 15.327223] Loaded X.509 cert ‘wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600’
ÿäVM 8001: I/TC: WARNING (insecure configuration): Failed to commit dirh counter 92
ÿá[ 16.076768]
[ 17.626440] iommu smmu3.0x0000008806000000: IOMMU driver was not able to establish FW requested direct mapping.
ÿçINFO: END TASK:MB
INFO: END TASK:MB
ÿá[ 18.743889] nvidia 0000:01:00.0: [drm] No compatible format found
[ 18.963657] nvidia-modeset: WARNING: HW supports 8 heads. Limiting to 4 heads
[ 18.965511] nvidia-modeset: WARNING: GPU:0: The head configuration (0xff) is inconsistent with the number of heads (4)
ÿçINFO: END TASK:MB
INFO: END TASK:MB
ÿá
Password: [ 27.954501] platform sound: deferred probe pending: tegra-audio-graph-card: parse error
Welcome to Ubuntu 24.04.3 LTS (GNU/Linux 6.8.12-rt-tegra aarch64)
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the ‘unminimize’ command.
Expanded Security Maintenance for Applications is not enabled.
0 updates can be applied immediately.
Enable ESM Apps to receive additional future security updates.
See Ubuntu Expanded Security Maintenance | Security | Ubuntu or run: sudo pro status
To run a command as administrator (user “root”), use “sudo ”.
See “man sudo_root” for details.
nvidia@nvidia:~$ ÿçINFO: END TASK:MB
INFO: END TASK:MB
ÿá
nvidia@nvidia:~$
nvidia@nvidia:~$
nvidia@nvidia:~$ [ 57.917817] rcu: INFO: rcu_sched self-detected stall on CPU
[ 57.917823] rcu: 0-…: (5249 ticks this GP) idle=a4ec/1/0x4000000000000000 softirq=2902/2902 fqs=2624
[ 70.630040] rcu: INFO: rcu_sched detected expedited stalls on CPUs/tasks: { 0-… } 5707 jiffies s: 1105 root: 0x1/.
[ 70.630046] rcu: blocking rcu_node structures (internal RCU debug):
[ 70.630052] NMI backtrace for cpu 0
nvidia@nvidia:~$
nvidia@nvidia:~$
nvidia@nvidia:~$
When the screen is not connected, log in to the device via SSH, then use the command sudo reboot. I tried it a dozen times, and it didn’t appear.
Is there any way to solve this problem?
This issue will affect the usage of the equipment by the customers.
Will this issue happen if you are not using RT kernel?
Just want to confirm is related to RT.
Standard version: Connect the screen, and after turning on the device, click the restart button on the interface to reboot. After trying more than 20 times, it was able to start up normally each time. …
Please follow the steps in Jetson AGX Thor FAQ
To build RT kernel.
