Hi, we have Jetson AGX xavier 32GB dev kit and when we power off through OS , system is restarting.
Can you please check and let us know the reason for this.
hello mgopi7416448813,
may I know which JetPack release you’re working with, what’s the commands you’re used to reproduce the issue.
BTW, you may also setup a serial console to gather the logs for reference. thanks
We are using jetpack 4.4.1 and we have tried all the commands (power off, shutdown, shutdown -h now) and the result is same.
could you please also setup a serial console to gather the logs for reference.
according to Jetson AGX Xavier Developer Kit User Guide, you may access the serial console via J501 micro-USB port.
thanks
