Jetson Jetpack6.2 fatal error: extensions/tensorops/core/CVError.h: No such file or directory #41
build isaac_ros_dnn_stereo_depth find some logs as follow:
/code/isaac_ros_dnn_stereo_depth/gxf_isaac_ess/gxf/gems/dnn_inferencer/inferencer/Errors.h:17:10: fatal error: extensions/tensorops/core/CVError.h: No such file or directory
include “extensions/tensorops/core/CVError.h”
compilation terminated.
gmake[2]: *** [CMakeFiles/gxf_isaac_ess.dir/build.make:146: CMakeFiles/gxf_isaac_ess.dir/gxf/gems/dnn_inferencer/inferencer/TensorRTInferencer.cpp.o] Error 1
In file included from /code/isaac_ros_dnn_stereo_depth/gxf_isaac_ess/gxf/extensions/ess/components/ess_inference.hpp:26,
from /code/isaac_ros_dnn_stereo_depth-3.2.0/gxf_isaac_ess/gxf/extensions/ess/ess.cpp:18:
Hi @yongg1232006 ,
I would recommend you to please reach out to JEtson Forum for better assiatnce.
