Jetson platform cannot find head file "CVError.h" and "Array.h"
ON Jetson Jetpack6.2 build isaac_ros_dnn_stereo_depth module ,find some error:fatal error: extensions/tensorops/core/CVError.h: No such file or directory.
how to slove it
Hi @yongg1232006, welcome to the NVIDIA developer forums!
Can you share which Jetson Platform you are using? Then I can sort you to the correct Forum category.
Jetson Agx Orin JetPack6.2 ISAAC_ROS3.2
Jetson Agx Orin Jetpack6.2 ISAAC_ROS3.2
build isaac_ros_dnn_stereo_depth find some error as follow:
/code/isaac_ros_dnn_stereo_depth/gxf_isaac_ess/gxf/gems/dnn_inferencer/inferencer/Errors.h:17:10: fatal error: extensions/tensorops/core/CVError.h: No such file or directory
17 | include “extensions/tensorops/core/CVError.h”
compilation terminated.
gmake[2]: *** [CMakeFiles/gxf_isaac_ess.dir/build.make:146: CMakeFiles/gxf_isaac_ess.dir/gxf/gems/dnn_inferencer/inferencer/TensorRTInferencer.cpp.o] Error 1
In file included from /code/isaac_ros_dnn_stereo_depth/gxf_isaac_ess/gxf/extensions/ess/components/ess_inference.hpp:26,
from /code/isaac_ros_dnn_stereo_depth/gxf_isaac_ess/gxf/extensions/ess/ess.cpp:18:
how to slove this problem?
thanks!
I find CVError.h in isaac_ros_image_pipeline package
