Jetson Jetpack6.2 fatal error: extensions/tensorops/core/CVError.h: No such file or directory
Jetson Jetpack6.2 build isaac_ros_dnn_stereo_depth find some error as follow:
/code/isaac_ros_dnn_stereo_depth/gxf_isaac_ess/gxf/gems/dnn_inferencer/inferencer/Errors.h:17:10: fatal error: extensions/tensorops/core/CVError.h: No such file or directory
17 | include “extensions/tensorops/core/CVError.h”
compilation terminated.
gmake[2]: *** [CMakeFiles/gxf_isaac_ess.dir/build.make:146: CMakeFiles/gxf_isaac_ess.dir/gxf/gems/dnn_inferencer/inferencer/TensorRTInferencer.cpp.o] Error 1
In file included from /media/yong/46f38944-a02a-4875-ab52-6da0d895edcf/code/isaac_ros_dnn_stereo_depth-3.2.0/gxf_isaac_ess/gxf/extensions/ess/components/ess_inference.hpp:26,
from /code/isaac_ros_dnn_stereo_depth-3.2.0/gxf_isaac_ess/gxf/extensions/ess/ess.cpp:18:
how to slove this problem?
thanks!
Jetson AGX Orin Jetpack6.2 ISAAC_ROS
In file included from /code/isaac_ros_dnn_stereo_depth-3.2.0/gxf_isaac_ess/gxf/extensions/ess/components/ess_inference.hpp:26,
thanks!
Hi @yongg1232006
Have you checked if your Jetson has all the CUDA and libraries installed?
Can you help me describe the setup you’re using more clearly?
Best,
Raffaello
Hi,Raffaello!
I have install JetPack6.2. JetPack6.2 contain CUDA and Tensor. runing platform is JetSon AGX Orin.
when colcon build isaac_ros_dnn_stereo_depth package,find some errors as follow:
from /code/isaac_ros_dnn_stereo_depth/gxf_isaac_ess/gxf/extensions/ess/ess.cpp:18:
I have find CVError.h in isaac_ros_image_pipeline repository
