Jetson Nano 2GB – JetBot Setup Issues
Hi there!
I’m trying to set up a Jetson Nano 2GB for JetBot, but I’ve run into an issue.
I’m confused about the JetBot setup process. I learned that I need to first set up a plain JetPack image before using a JetBot SD image. I am trying to set the Jetson up without the JetBot extensions, but the setup is not working as expected. .
  1. Installer Error: When using the JetPack image, I get the following message: “The installer encountered an unrecoverable error. A desktop session will now be run so that you may investigate the problem or try installing again.”
  2. After that, I sometimes get a prompt asking for “localhost login,” but the default credentials do not work.
  3. JetBot images do not work at all when I try to boot them directly.
I also tried different SD cards but that did not change the result in any way.
I couldn’t find any other sources to help me troubleshoot the issue and I’m completely new to Jetson and this forum, so I apologize if I missed an obvious solution. Any help would be greatly appreciated! If needed I can attach pictures of the errors.
Many thanks in advance! :)
Are youi referring to JetBot?
You may ask a question and discuss JetBot related topics on the JetBot GitHub Discussions
