hi, I am using the jetson nano for the first time and i’m trying to install jetpack but after configuration it restarts and after a while the screen blacks out. I’ve tried re-flashing it with other versions too but its the same.
Please check Debug tips when you hit any issue (fail to boot/ keep reboot …etc) - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums to see if can help.
There are actually not many “real Jetson nano devkit” in the market now. You better checking if your sdcard slot is on the module or on the carrier board…
If you don’t know what I am talking about, then it requires another explanation…
