Debug tips when you hit any issue (fail to boot/ keep reboot ...etc)
I would like to share some tips for someone who has problem and wants to file a topic for their issues.
This thread will guide you what are necessary files/information you should prepare when you file a topic. Also, such rule is not limited to jetson nano. You could follow this for every jetson forum.
0. For jetson nano/nx sdcard module boot issue
This one is common so let me put it here.
If you didn’t try sdkmanager before, please put your sdcard to the board, put the board into recovery mode and find a native x64 ubuntu 18.04 host to install sdkmanager and flash it to your jetson.
Sdkmanager:https://developer.nvidia.com/nvidia-sdk-manager
How to put device into recovery mode: https://developer.nvidia.com/embedded/dlc/r32-3-1_Release_v1.0/t186ref_release_aarch64/l4t_quick_start_guide.txt
SDKmanager will reflash the QSPI-NOR over your jetson module. So if your board crashed in bootoloader stage, it will be recovered.
However, replacing SDcard image is not able to recover such error.
1. Please share the detailed info of your board
You should tell what kind of carrier board you are using.
If that carrier board is not a NVIDIA Development kits (devkit), we usually say it is a custom carrier board.
If a custom board is made by yourself, please try to attach the board schematics if possible. Or you may contact the vendor of this board for help.
2. Please share the software version and driver package running on your board.
Such software version is not just something like “ubuntu16.04/18.04”. What we want to know is the jetpack version.
3. Please share the full error log from dmesg, uart serial console and syslog.
Please avoid to just say some simple description like “my usb keyboard is broken” or “my board is not booting”…etc., and provide nothing.
This kind of issue has lots of reasons behind. Other people are not able to directly tell what is wrong by those description. We need your text log.
  1. If this issue is related to some peripheral, please open a terminal and enter command “dmesg” to dump log.
  2. If this issue is related to boot, please dump the uart serial console log, you can refer to this page to know how to dump. → Jetson/General debug - eLinux.org
  3. If this issue is related to non-kernel software problem, please also attach the syslog, which is located in /var/log/syslog/ on your device.
    If you don’t know what kind of log you should share, share these 3 altogether.
Also, please avoid sharing your log as a picture/image file here. We cannot search specific keyword from a image file. A full text log will be the best one.
4. Please search other existing topics first before you file your own topic.
Other people may already asked similar problem as your case. Search such topics before asking can save your own time waiting for reply.
5. Please try to reproduce your issue with Development kit (devkit) and tell your commands/steps to reproduce issue clearly.
The only tool NV can help debug on is the NV development kit, thus, if this is an issue that triggered by your software application, please try to run it on devkit and see if it can reproduce.
After you confirm the steps, please share the application, code, steps and whatever you have modified to us so that we can check it locally.
6. Please read document and other files first.
We put all the public sources and document in this download center. If you want to check the source code, please directly check this website.
https://developer.nvidia.com/embedded/downloads
7. Please preview your comment before you file the topic
Some users like to directly copy and paste their log or code to forum and they don’t really notice the format of their code is totally messed up or truncated by the forum system. Thus, please preview and review your comment. Or just attach it as a text file instead of copy & paste.
Jeston Nano developer kit doesn't boot up
Jetson Nano not displaying?
Jaston Xavier NX Boot failed
Jetson Nano unbootable
GPU has disappeared from bus
Xorg occupies resources soaring, causing the system to freeze
Jetson Nano Boot Failed
Jetson Nano 4 GB Developer Kit is not working
Jetson Nano Development Board is not booting up
Jetsono nano will not boot
Jetson Nano not booting
I'm having trouble setting up my new Nvidia Jetson Nano
Jetson Nano B01 (2GB version) fails to boot
Xavier NX p3668 DOES NOT OPEN
NVIDIA Jetson Nano BO1 not booting up
Jetson xavier nx does not boot up
Jetson nano usb camera fails to boot and not working
NvTbootKernelDTB is corrupted!
Jetson do not Boot
Jetson Xavier Nano SD card has software installed but wont boot
Jetson Restarting NvRmMemInit
Seagate 5TB H/D kills the USB 3 port on TX2
GPU error
Jetson Nano can not booting normally after backup
Jetson Nano fails to boot and cannot enter the system
Jetson nano cannot print uboot messages by serial
Xavier add FDT unable to start the system
In the startup process will occasionally encounter the following situation,what should i do?
Dpkg error for:nvidia-l4t-init_32.4.2-20200408182156_arm64.deb
Jetson nano hdmi display unstable
Jetson Xavior NX
Wireless disappear when I use usb + putty for first configuration jetson nano developer kit 2gb
Jetson nano boards doesn't boot after initial setup
Nano freezes on Nvidia logo
Jetson Nano 2GB Developer Kit not getting passed startup page
Jetson Nano Developer Kit A02 EBT failed!
My board is not starting
How to flash board with sdkmanager
Jetson Nano no screen
Jetson TX2 Doesn't Power On
Jetson nano board fails to boot
Stay in black screen with cursor flashing while booting
Jetson Nano 2gb Not Booting / Powering On
It will show other picture after show logo
Jetson nano dev kit model P3450 stop working
Flashing fresh Jetson nano sd card DTB partition
Jetson xavier AGX has not hdmi output
Jetson Nano 2gb display not working
The /install_full.sh -m imx477 and /opt/nvidia/jetson-io/jetson-io.py can conflict with each other
Jetson Nano not booting up, LED remains lit
I have a problem with the Jeston Nano J1010 Freeze screen Nvidia
Jetson nano can't booting
Jetson Orin Nano Installation with SDKManager Doesn't Work | Stops at 37%
Cannot turn on jetson nanona
About Memory Extension with Sd card
Jetson Nano Dev-Kit A not working
Dev kit Jetson Nano B01 kernel error
Has my Jetson Nano Develpoer Kit died?
I have 10 jetson nanos. All are randomly not booting. All are powered using barrel jack Poweredn
Nano keeping restar,can't into recovery mode to flash
Jetson nano failed to start up
Jetson Nano Fails to Boot - Kernel Panic Error
I have a video output problem in my jetson nano
reComputer J1010 (P3448 Kit) Boot Failur
JETSON NANO STUCK ON NVIDIA LOGO
Jetson Nano B01 Not Booting
Flashed image successfully, but Jetson Nano 2GB fails to install on boot and can't be used
I bought a new JETSON NANO. Its flash drive is broken and it won't boot. It just hangs on the NVIDIA screen
Jetson Power Issue
Jetson nano orin - gowno ktore nie dziala
Jetson nano os corrupted and usb ports also not working
Custom kernel, slow USB device enumeration on boot
Custom Carrier Board: Jetson does not boot
Xavier NX could not boot up
Jetson Nano B01 won't boot anymore - no visual via HDMI oder DP
JETSON Nano 4gb not booting with SD card
Jetson agx xavier not booting
JESTON NANO NO ENCIENDE
Why jetson nano can't power on while adding FDT in /boot/extlinux/extlinux.conf?
Jetson xavier nx not work
Jetson nano not boot
How to dump the boot log of the jetson nano device?
NX Xavier dev kit blank screen
Why does Jetson Nano not power up?
Nvidia Jetson nano freezes at Nvidia logo screen - Need Assistance
Nano won't connect to monitor
Booting - Getting started with Jetson Nano Developer Kit 4GB
The board is not booting while the power led is on
Jetson Nano FAQ
JETSON NANO POWER led is RED
I have a problem with flashing the SD card using the balena etcher. I’m using a 256 GB SD card and when I flash it with the SD card image after validating, it gives me an error of “flash failed”? What possible solutions to this?
Thank you!
This is usually related to flashing large micro sd cards. If you delete all partitions and format as NTFS first then the flash will validate.
Jetson nano was working fine 2-3 days ago when plugged the power supply after a few days. First Nvidia screen appears, then it turns off the display & doesn’t boot, but the green led is On. And I looked at the forum and tried solutions like switching power supplies for boot micro-USB and 5V jack, the processor was working fine checked with power sources, reflashing the SD-Card many times with different versions, then tried to connect Jetson Nano over serial using minicom on Ubuntu, also tried to recovery & reset through J40pin,tried to boot with USB also but results show negative. Any solutions, suggestions & how do I get the support if it’s a board issue.
Here is the report logs I am attaching bellow:
[ 1.168656] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.190672] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.196994] tegradc tegradc.1: dp: Failed for I2C write addr:80, size:1, stat:0x10000100 [ 1.217386] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.223683] tegradc tegradc.1: dp: Failed to write DPCD data. CMD Ox600, Status Ox10000100
[ 1.237036] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.243322] tegradc tegradc.1: dp: Failed to write DPCD data. CMD Ox600, Status Ox10000100
[ 1.256362] tegradc tegradc.1: dp: aux write got error (Ox10000100)
[ 1.262653] tegradc tegradc.1: dp: Failed to write DPCD data. CMD Ox600, Status Ox10000100
[ 1.275981] tegradc tegradc.1: dp: aux write got error (Ox10000100)
[ 1.282265] tegradc tegradc.1: dp: Failed to write DPCD data. CMD Ox600, Status Ox10000100
[ 1.290543] tegradc tegradc.1: dp: failed to exit panel power save mode (Oxfffffff2) [ 1.326963] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.327032] imx219 7-0010: board setup failed
[ 1.350851] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.350909) imx219 8-0010: board setup failed
[ 1.414870] tegradc tegradc.1: dp: aux write got error (Ox10000100)
[ 1.414874] tegradc tegradc.1: dp: Failed to write DPCD data. CMD Ox600, Status Ox10000100 1.419851] tegradc tegradc.1: dp: aux write got error (Ox10000100)
[ 1.419855] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status Ox10000100
[ 1.424829] tegradc tegradc.1: dp: aux write got error (Ox10000100)
[ 1.424832] tegradc tegradc.1: dp: Failed to write DPCD data. CMD Ox600, Status Ox10000100
[ 1.429660] tegradc tegradc.1: dp: aux-write got error (Ox10000100)
[ 1.429663] tegradc tegradc.1: dp: Failed to write DPCD data. CMD Ox600, Status. Ox10000100
[ 1.429666] tegradc 'tegradc.1: dp: failed to exit panel power save mode (Oxfffffff2)
[ 1.429669] hpd: ed id read prepare failed
cp: not writing through dangling symlink ‘etc/resolu.conf’
[ 1.898988] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.103394] using random self ethernet address
[ 3.118761] using random host ethernet address
[ 3.822117] random: crng init done
[ 3.825550) random: 7 urandom warning(s) missed due to ratelimiting
[ 4.027635] using random self ethernet address
[ 4.042287] using random host ethernet address
Hello
When i powered up my jetson Nano board, instead of getting green light, i am getting red light, can anyone help me to state this iisue
Stuck here. Tried different sd cards. Tried flashing with SDK manager, stuck at 99% forever. Please help.
output.log (28.9 KB)
please file a new topic in Jetson Nano forum and we could discuss your case there.
