Jetson Nano 4GB USB3 to USB2
It is known that USB 3 causes a lot of EMI. As the bandwidth is not required in my case, I would like to switch all ports back to USB2.1.
How to achieve that?
Thanks in advance.
Hi, what do you mean switch back to USB2.1? If you don’t use USB3 part, then it is USB2.0 port.
I just want to enforce USB 2 mode on the USB3 connectors using peripherals that support both modes.
no, it is not possible to do this in software.
