Jetson nano backup restore
Hi
I followed the above process for jetson nano backup after restoring we unable to boot the device .
Please show the booting log from the serial console so we know what’s going on.
Don’t just say something like we unable to boot the device.
dd clone of an SD card is generally pretty reliable. You should state if the SD card which was cloned is from the same Nano…if not, then the QSPI content on a different Nano might not be of the correct release to work with the one the original SD card worked with. Not all module QSPI flash content is compatible with all releases of SD card content. I only mention this because a correct dd clone, whereby the first SD card works, should also work with the new SD card. If they are from the same unit, then you’d need to get the serial console log which @DaveYYY mentions.
