Hey guys
We are trying to clone and restore and having issues with that.
Basically I have 2 SD cards. First 128GB SD card is fully working Xavier NX system with JP 4.4 and some additional software and configs for external hardware, etc. Second 64GB SD card is a fully working Xavier NX system with vanilla JP 4.4, i.e. original state of the first SD card. So the idea to clone the first and restore on many second ones.
We followed the documentation, i.e. used jumper for pin 9 and 10 to enter recovery mode, downloaded on the host machine JP 4.4 (the same version that is installed on Xavier NX), connected via USB.
It looks like clone was successful but with Error: Return value 14.
Restore failed the first time with Error: Return value 3.
But the second time it was successful.
Unfortunately the boot has failed.
I am attaching a file that has all logs and errors.
They are organized as following:
clone
command and logs (success, but some error value was returned)
copy to bootloader directory
command and logs (success)
restore first attempt
command and logs (failure)
restore second attempt
command and logs (success but loading error from SD card, sent image today a earlier about mount issues)
This what I see when I boot from the restored (second) SD card neil_nx_clone_copy_restore.log (178.8 KB)
We would really appreciate if someone could help us!
