I am experiencing the same issue as others. Got a Jetson Nano 2GB with a SDXC Sansdisc 64GB yesterday. Everything worked fine until I did a reboot for the updates. When rebooted, I see some log text on the screen briefly and then the screen goes blank. In the meantime I suppose I will reformat the SD card and just not update until this issue has been fixed.
EDIT
The solution that permafrost55 proposed worked like a charm. I didn’t even need to SSH into the Nano from a different computer by entering console mode using Ctrl+Alt+F1 instead.
I tested a bunch of trials with fresh images and here are the results. I also added a link to my Google Drive with all of the logs. If you’re having issues downloading the files let me know. I added “auth.log” from the “/var/log” folder, and “eipp.log”, “history.log”, “term.log” from the “var/log/apt” folder.
Before and after reboot logs were saved. Trials that rebooted with a blank screen were bypassed by logging in with sudo systemctl start gdm3.service and then the logs were saved.
Hopefully these trials will help the developers find a solution.
Also, @mdegans, I successfully built OpenCV 4.4 with your github (great work and thanks!) and noticed that sudo apt-get dist-upgrade is in the .sh file so added that trial here. I think that’s where my blank screen issue came from because I hadn’t run any of the other “upgrade” commands on my own.
Trial 1 Fresh image 1-1 Initial start-up logs 1-2sudo apt update
Before reboot logs.
Result: Successful reboot 1-3sudo apt-get update
Before reboot logs.
Result: Successful reboot 1-4sudo apt upgrade
Before and after reboot logs.
Result: Failed reboot. Blank screen.
Trial 2 Fresh image 2-1sudo apt-get upgrade
Trial 3 Fresh image 3-1sudo apt-get dist-upgrade
Trial 4 Fresh image 4-1sudo apt upgrade
No upgrade actually took place. It said that no packages needed upgrading.
Result: Successful reboot 4-2sudo apt upgrade - A second time.
Upgrade actually happened.
Trial 5 Fresh image 5-1 Ubuntu only update prompted by pop-up window. Approx 231MB.
Trial 6 Fresh image 6-1 Full software update by navigating to “Preferences > Software Updater”. Approx 414MB.
Before doing the apt-get upgrade, you may need to hold systemd to let it not going to upgrade.
This issue only happens to lightdm based platform. Thus, if you are using default jetpack release, only Nano-2gb will have this problem. Nano-4GB device is using gdm3 but not lightdm so will have no such issue.
Thus, if you are using nano-4gb and you have a blanked screen, please file a new topic for it because this thread is different from your case.
@WayneWWW It is dissapointing that there are only workarounds and not a solution. When Nvidia will issue a solution?. I am not very hsppy with having to use a workaround for something that should work out of the box.
Here is a quick fix. The problem was on a fresh install you get asked if you would gdm3 or lightdm as your display manager. I selected lightdm because it seemed faster and more lightweight. After rebooting I got the blank screen. Clearly lightdm does not work with the nano. To fix it, restart your device, when you get to blank screen do:
cntrl + alt + f1 => gets you to terminal sudo dpkg-reconfigure gdm3 reboot
My OS ran fine after that. No need to rewrite OS onto sd card etc.
The problem is due to the greeter as I mentioned. But not totally lightdm.
Changing to gdm3 was also a method mentioned by other users in previous comments.
However, nano-2gb user is not able to use gdm3 because only 2GB ram is available.
