Jetson Nano 2gb display not working
Dear Nvidia Dev Team,
We are facing display issue a lot, Where the new lot have this issue of No Display, The power Led is turned on But With Nvidia Jetson 2GB Dev Kit - no Display, Out of 20 Units , 11-12 Units have the same Problem, This is not something which we have faced with Jetson Nano, Since half the LOT is working, their is no issue with our setup, But the other half which is failing points out the QC of this LOT, Please help us with a solution or Process as the failure rate is really high.
I have checked the carrier board it’s working, I changed the Jetson board SOM on the carrier board and the issue is resolved
Thank you for your time
Is this issue just “display not working” or actually the board is not even booting into kernel? or you cannot tell?
Carrier board is working fine, because I changed the SOM board and I got the display, I currently have 22 pieces of Jetson nano not showing display. Green Led light is on, on the carrier board.
When we power the Jetson nano we get the display of Nvidia and it remains there if the OS is not flashed on the SD card,(working Jetson nano 2gb)
The current issue is I don’t get any display when I power the Jetson nano
Thank you
So you are basically not sure if the board really boots up right?
I didn’t mean anything about hardware or power. I mean the software. For example, you cannot tell if it is fails to boot into ubuntu. You only saw monitor showed nothing.
Is that your current situation?
Sorry if u didn’t understand me
No software is booted because no display no Nvidia no black screen with some statements on it
When Jetson nano is turned on without the SD card, it turns on with the Nvidia screen showing no SD card inserted.
Right now when I turn on the Jetson nano I don’t see Nvidia screen and no SD card notification (no display).
Now I have some Jetson nano 2gb which works with the SD card and in some even with flashed SD card it doesn’t show any display so I am not sure whether it’s booted or not, I am taking output from HDMI.
So I have two separate issues.
Then it is time to learn how to check issue. Software is not judged by using a monitor to check. For example, maybe the display driver is dead but your device still boots. In this situation, the system boots but just monitor not able to render.
It is totally different cases between such situation or something else that even fail to boot into kernel.
Take some modules out and dump the log from uart pin.
If you don’t want to and don’t have time to do this, then just flash your module with sdkmanager from another x86 host PC. Most of issues would be resolved by this.
If you want to know why you have to flash with sdkmanager, I already explained that in point 0 of this post. You can take a look.
So u are saying if I do this what u mentioned above I will get display without SD card right?
Because it’s in our QC protocol to check the display without SD card first and then flash SD card and put into the Jetson nano
Thank you
No, I am not talking about that. I mean we just reflash the whole board first. Sdcard is still needed.
Okay I will follow all the instructions provided by you and will share the results here
If you need a really diagnoses about what happened on your board, then you need dump log as my previous comment.
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB1, 16:01:16
Press CTRL-A Z for help on special keys
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x50
[0000.151] RamCode = 1
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x801f0
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.178] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.198] Lp0 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.204] BpmpFw Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.210] GSC1 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.216] Resize the SecureOs Carveout to 0x00100000
[0000.221] GSC2 Carveout Base=0x00000000ff900000 Size=0x00100000
[0000.226] GSC4 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.232] GSC5 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.238] GSC3 Carveout Base=0x00000000bf800000 Size=0x00200000
[0000.244] RamDump Carveout Base=0x0000000000000000 Size=0x00000000
[0000.250] Platform-DebugCarveout: 0
[0000.253] Nck Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.259] Non secure mode, and RB not enabled.
[0000.263] BoardID = 3448, SKU = 0x3
[0000.266] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.270] Nano-SD: checking PT table on QSPI …
[0000.274] Initialize FailControl
[0000.277] Read PT from (2:0)
[0000.308] PT crc32 and magic check passed.
[0000.312] Using BFS PT to query partitions
[0000.317] Loading Tboot-CPU binary
[0000.346] Verifying TBC in OdmNonSecureSBK mode
[0000.356] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.363] Bootloader downloaded successfully.
[0000.367] Downloaded Tboot-CPU binary to 0xa0000258
[0000.372] MAX77620_GPIO5 configured
[0000.375] CPU power rail is up
[0000.378] CPU clock enabled
[0000.382] Performing RAM repair
[0000.385] Updating A64 Warmreset Address to 0xa00002e9
[0000.390] BoardID = 3448, SKU = 0x3
[0000.393] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.397] Nano-SD: checking PT table on QSPI …
[0000.401] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.407] Loading NvTbootBootloaderDTB
[0000.474] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.543] Bootloader DTB Load Address: 0x83000000
[0000.547] BoardID = 3448, SKU = 0x3
[0000.551] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.555] Nano-SD: checking PT table on QSPI …
[0000.559] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.565] Loading NvTbootKernelDTB
[0000.631] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.700] Kernel DTB Load Address: 0x83100000
[0000.704] BoardID = 3448, SKU = 0x3
[0000.707] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.711] Nano-SD: checking PT table on QSPI …
[0000.716] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.723] Loading cboot binary
[0000.839] Verifying EBT in OdmNonSecureSBK mode
[0000.881] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.888] Bootloader downloaded successfully.
[0000.892] BoardID = 3448, SKU = 0x3
[0000.895] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.899] Nano-SD: checking PT table on QSPI …
[0000.903] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.910] PT: Partition NCT NOT found !
[0000.913] Warning: Find Partition via PT Failed
[0000.918] Next binary entry address: 0x92c00258
[0000.922] BoardId: 3448
[0000.927] Overriding pmu board id with proc board id
[0000.932] Display board id is not available
[0000.936] No Bpmp FW loaded
[0000.938] Not loading WB0 as no bpmp/sc7entry fw
[0000.943] Set NvDecSticky Bits
[0000.946] GSC2 address ff93fffc value c0edbbcc
[0000.953] GSC MC Settings done
[0000.955] BoardID = 3448, SKU = 0x3
[0000.959] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.963] Nano-SD: checking PT table on QSPI …
[0000.967] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.974] TOS Image length 53680
[0000.977] Monitor size 53680
[0000.980] OS size 0
[0000.995] Secure Os AES-CMAC Verification Success!
[0000.999] TOS image cipher info: plaintext
[0001.003] Loading and Validation of Secure OS Successful
[0001.019] NvTbootPackSdramParams: start.
[0001.024] NvTbootPackSdramParams: done.
[0001.028] Tegraboot started after 51867 us
[0001.032] Basic modules init took 953930 us
[0001.036] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.042] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.047] Next stage binary read took 11286 us
[0001.051] Carveout took -69913 us
[0001.054] CPU initialization took 106069 us
[0001.058] Total time taken by TegraBoot 1001372 us
[0001.063] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:09:37, Jul 26 2021
ERROR: Error initializing runtime service trusty_fast
[0001.185] RamCode = 1
[0001.189] LPDDR4 Training: Read DT: Number of tables = 2
[0001.194] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.207] EMC Training Successful
[0001.210] 408000 not found in DVFS table
[0001.217] RamCode = 1
[0001.220] DT Write: emc-table@204000 succeeded
[0001.226] DT Write: emc-table@1600000 succeeded
[0001.230] LPDDR4 Training: Write DT: Number of tables = 2
[0001.268]
[0001.269] Debug Init done
[0001.272] Marked DTB cacheable
[0001.275] Bootloader DTB loaded at 0x83000000
[0001.280] Marked DTB cacheable
[0001.282] Kernel DTB loaded at 0x83100000
[0001.286] DeviceTree Init done
[0001.299] Pinmux applied successfully
[0001.304] gicd_base: 0x50041000
[0001.307] gicc_base: 0x50042000
[0001.310] Interrupts Init done
[0001.314] Using base:0x60005090 & irq:208 for tick-timer
[0001.320] Using base:0x60005098 for delay-timer
[0001.324] platform_init_timer: DONE
[0001.327] Timer(tick) Init done
[0001.331] osc freq = 38400 khz
[0001.335]
[0001.336] Welcome to L4T Cboot
[0001.339]
[0001.340] Cboot Version: 00.00.2018.01-t210-c952b4e6
[0001.345] calling constructors
[0001.348] initializing heap
[0001.351] initializing threads
[0001.354] initializing timers
[0001.357] creating bootstrap completion thread
[0001.361] top of bootstrap2()
[0001.364] CPU: ARM Cortex A57
[0001.367] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.372] initializing platform
[0001.379] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.384] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.388] Macronix QSPI chip present
[0001.392] SPI device register
[0001.394] init boot device
[0001.397] allocating memory for boot device(SPI)
[0001.402] registering boot device
[0001.410] QSPI bdev is already initialized
[0001.414] Enable APE clock
[0001.416] Un-powergate APE partition
[0001.420] of_register: registering tegra_udc to of_hal
[0001.425] of_register: registering inv20628-driver to of_hal
[0001.431] of_register: registering ads1015-driver to of_hal
[0001.436] of_register: registering lp8557-bl-driver to of_hal
[0001.442] of_register: registering bq2419x_charger to of_hal
[0001.448] of_register: registering bq27441_fuel_gauge to of_hal
[0001.459] gpio framework initialized
[0001.463] of_register: registering tca9539_gpio to of_hal
[0001.468] of_register: registering tca9539_gpio to of_hal
[0001.473] of_register: registering i2c_bus_driver to of_hal
[0001.479] of_register: registering i2c_bus_driver to of_hal
[0001.484] of_register: registering i2c_bus_driver to of_hal
[0001.490] pmic framework initialized
[0001.493] of_register: registering max77620_pmic to of_hal
[0001.499] regulator framework initialized
[0001.503] of_register: registering tps65132_bl_driver to of_hal
[0001.509] initializing target
[0001.515] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.523] board ID = D78, board SKU = 3
[0001.526] Skipping Z3!
[0001.531] fixed regulator driver initialized
[0001.550] initializing OF layer
[0001.553] NCK carveout not present
[0001.556] Skipping dts_overrides
[0001.560] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.577] I2C Bus Init done
[0001.579] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.589] I2C Bus Init done
[0001.592] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.602] I2C Bus Init done
[0001.605] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.615] I2C Bus Init done
[0001.618] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.628] I2C Bus Init done
[0001.631] of_children_init: Ops found for compatible string maxim,max77620
[0001.641] max77620_init using irq 118
[0001.646] register ‘maxim,max77620’ pmic
[0001.650] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.657] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.667] I2C Bus Init done
[0001.671] NCK carveout not present
[0001.680] Find /i2c@7000c000’s alias i2c0
[0001.684] get eeprom at 1-a0, size 256, type 0
[0001.693] Find /i2c@7000c500’s alias i2c2
[0001.697] get eeprom at 3-a0, size 256, type 0
[0001.701] get eeprom at 3-ae, size 256, type 0
[0001.706] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.711] I2C slave not started
[0001.714] I2C write failed
[0001.717] Writing offset failed
[0001.720] eeprom_init: EEPROM read failed
[0001.724] pm_ids_update: eeprom init failed
[0001.728] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.758] pm_ids_update: The pm board id is 3448-0003-400
[0001.765] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0001.773] pm_ids_update: pm id update successful
[0001.777] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.807] pm_ids_update: The pm board id is 3542-0000-201
[0001.814] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0001.822] pm_ids_update: pm id update successful
[0001.852] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.858] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0001.866] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.871] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0001.880] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2f:2c:fd
[0001.886] Plugin Manager: Parse ODM data 0x000a4000
[0001.898] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7
[0001.913] Find /i2c@7000c000’s alias i2c0
[0001.916] get eeprom at 1-a0, size 256, type 0
[0001.925] Find /i2c@7000c500’s alias i2c2
[0001.929] get eeprom at 3-a0, size 256, type 0
[0001.934] get eeprom at 3-ae, size 256, type 0
[0001.938] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.943] I2C slave not started
[0001.946] I2C write failed
[0001.949] Writing offset failed
[0001.952] eeprom_init: EEPROM read failed
[0001.956] pm_ids_update: eeprom init failed
[0001.960] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.990] pm_ids_update: The pm board id is 3448-0003-400
[0001.996] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0002.003] pm_ids_update: pm id update successful
[0002.008] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.038] pm_ids_update: The pm board id is 3542-0000-201
[0002.044] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0002.051] pm_ids_update: pm id update successful
[0002.082] Add serial number:1424320072302 as DT property
[0002.089] Applying platform configs
[0002.095] platform-init is not present. Skipping
[0002.100] calling apps_init()
[0002.106] Couldn’t find GPT header
[0002.110] Proceeding to Cold Boot
[0002.113] starting app android_boot_app
[0002.117] Device state: unlocked
[0002.120] display console init
[0002.129] could not find regulator
[0002.152] hdmi cable not connected
[0002.155] is_hdmi_needed: HDMI not connected, returning false
[0002.161] hdmi is not connected
[0002.164] sor0 is not supportDT entry for leds-pwm not found
e[0002.173] d
[0002.174] display_console_init: no valid display out_type
[0002.182] subnode volume_up is not found !
[0002.186] subnode back is not found !
[0002.189] subnode volume_down is not found !
[0002.194] subnode menu is not found !
[0002.197] Gpio keyboard init success
[0002.278] found decompressor handler: lz4-legacy
[0002.292] decompressing blob (type 1)…
[0002.357] display_resolution: No display init
[0002.361] Failed to retrieve display resolution
[0002.366] Could not load/initialize BMP blob…ignoring
[0002.442] decompressor handler not found
[0002.446] load_firmware_blob: Firmware blob loaded, entries=2
[0002.451] XUSB blob version 0 size 126464 @ 0x92ca828c
[0002.457] -------> se_aes_verify_sbk_clear: 747
[0002.462] se_aes_verify_sbk_clear: Error
[0002.466] SE operation failed
[0002.469] bl_battery_charging: connected to external power supply
[0002.478] display_console_ioctl: No display init
[0002.482] switch_backlight failed
[0002.488] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.496] MSC Partition not found
[0002.502] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.509] USP partition read failed!
[0002.513] blob_init: blob-partition USP header read failed
[0002.518] android_boot Unable to update recovery partition
[0002.524] kfs_getpartname: name = LNX
[0002.527] Loading kernel from LNX
[0002.536] Found 19 BFS partitions in “spiflash0”
[0002.861] load kernel from storage
[0002.866] decompressor handler not found
[0003.135] Successfully loaded kernel and ramdisk images
[0003.140] board ID = D78, board SKU = 3
[0003.145] sdmmc node status = okay
[0003.148] sdcard instance = 0
[0003.151] sdmmc cd-inverted
[0003.154] sdcard gpio handle 0x5a
[0003.157] sdcard gpio pin 0xc9
[0003.160] sdcard gpio flags 0x0
[0003.163] vmmc-supply 0x9a
[0003.166] cd_gpio_pin = 201
[0003.168] pin_state = 0
[0003.171] Found sdcard
[0003.173] SD-card IS present …
[0003.176] load_and_boot_kernel: SD card detected OK
[0003.182] display_resolution: No display init
[0003.186] Failed to retrieve display resolution
[0003.191] bmp blob is not loaded and initialized
[0003.195] Failed to display boot-logo
[0003.199] NCK carveout not present
[0003.202] Skipping dts_overrides
[0003.205] NCK carveout not present
[0003.215] Find /i2c@7000c000’s alias i2c0
[0003.219] get eeprom at 1-a0, size 256, type 0
[0003.228] Find /i2c@7000c500’s alias i2c2
[0003.232] get eeprom at 3-a0, size 256, type 0
[0003.236] get eeprom at 3-ae, size 256, type 0
[0003.241] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.246] I2C slave not started
[0003.249] I2C write failed
[0003.252] Writing offset failed
[0003.255] eeprom_init: EEPROM read failed
[0003.259] pm_ids_update: eeprom init failed
[0003.263] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.293] pm_ids_update: The pm board id is 3448-0003-400
[0003.300] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0003.308] pm_ids_update: pm id update successful
[0003.312] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.342] pm_ids_update: The pm board id is 3542-0000-201
[0003.349] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0003.357] pm_ids_update: pm id update successful
[0003.387] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.393] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.401] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.406] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.415] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2f:2c:fd
[0003.421] Plugin Manager: Parse ODM data 0x000a4000
[0003.433] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7
[0003.441] Add serial number:1424320072302 as DT property
[0003.449] Updated bpmp info to DTB
[0003.454] Updated initrd info to DTB
[0003.457] “proc-board” doesn’t exist, creating
[0003.463] Updated board info to DTB
[0003.467] “pmu-board” doesn’t exist, creating
[0003.472] Updated board info to DTB
[0003.476] “display-board” doesn’t exist, creating
[0003.482] Updated board info to DTB
[0003.485] “reset” doesn’t exist, creating
[0003.490] Updated reset info to DTB
[0003.493] display_console_ioctl: No display init
[0003.498] display_console_ioctl: No display init
[0003.502] display_console_ioctl: No display init
[0003.507] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype
[0003.539] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.544] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[0003.557] Updated bootarg info to DTB
[0003.561] Adding uuid 000000016450b700200000000cfe0400 to DT
[0003.567] Adding eks info 0 to DT
[0003.572] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.578] Updated memory info to DTB
[0003.586] set vdd_core voltage to 1125 mv
[0003.590] setting ‘vdd-core’ regulator to 1125000 micro volts
[0003.596] Found secure-pmc; disable BPMP
U-Boot 2020.04-g46e4604c78 (Jul 26 2021 - 12:09:42 -0700)
SoC: tegra210
Model: NVIDIA Jetson Nano 2GB Developer Kit
Board: NVIDIA P3541-0000
DRAM: 2 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash… SF: Detected mx25u3235f with page size 25B
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
845 bytes read in 28 ms (29.3 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7160133 bytes read in 332 ms (20.6 MiB/s)
Retrieving file: /boot/Image
34484232 bytes read in 1516 ms (21.7 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resiz
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 000000008317ae79
copying carveout for /host1x@50000000/dc@54200000…
copying carveout for /host1x@50000000/dc@54240000…
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5496-d5000) (1
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 3f800000
[ 0.000000] OF: fdt: - bfa00000 , 3fe00000
[ 0.000000] OF: fdt: - ffa00000 , 600000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 1.272349] imx219 6-0010: imx219_board_setup: error during i2c read probe ()
[ 1.280011] imx219 6-0010: board setup failed
[ 2.274700] cgroup: cgroup2: unknown option “nsdelegate”
[ 2.340581] soctherm: OC ALARM 0x00000001
[ 3.342932] soctherm: OC ALARM 0x00000001
[ 3.515409] using random self ethernet address
[ 3.520189] using random host ethernet address
[ 4.112701] random: crng init done
[ 4.116104] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.346310] soctherm: OC ALARM 0x00000001
[ 4.454128] using random self ethernet address
[ 4.460455] using random host ethernet address
[ 5.353157] soctherm: OC ALARM 0x00000001
[ 6.354362] soctherm: OC ALARM 0x00000001
[ 7.410161] soctherm: OC ALARM 0x00000001
[ 7.867611] Bridge firewalling registered
[ 8.511811] soctherm: OC ALARM 0x00000001
[ 9.736498] soctherm: OC ALARM 0x00000001
Ubuntu 18.04.5 LTS byonyks-desktop ttyS0
byonyks-desktop login: [ 10.762626] soctherm: OC ALARM 0x00000001
[ 12.180314] soctherm: OC ALARM 0x00000001
[ 15.459807] soctherm: OC ALARM 0x00000001
[ 16.744140] soctherm: OC ALARM 0x00000001
[ 18.044604] soctherm: OC ALARM 0x00000001
[ 80.057847] soctherm: OC ALARM 0x00000001
[ 82.415025] soctherm: OC ALARM 0x00000001
[ 99.047635] soctherm: OC ALARM 0x00000001
[ 267.682630] soctherm: OC ALARM 0x00000001
[ 787.682298] soctherm: OC ALARM 0x00000001
[ 910.915264] soctherm: OC ALARM 0x00000001
[ 1167.681337] soctherm: OC ALARM 0x00000001
[ 1297.682468] soctherm: OC ALARM 0x00000001
[ 1687.682433] soctherm: OC ALARM 0x00000001
[ 1937.681367] soctherm: OC ALARM 0x00000001
[ 2067.682263] soctherm: OC ALARM 0x00000001
[ 2181.411470] soctherm: OC ALARM 0x00000001
[ 2197.681986] soctherm: OC ALARM 0x00000001
[ 2241.917869] soctherm: OC ALARM 0x00000001
[ 2327.681052] soctherm: OC ALARM 0x00000001
[ 2457.682309] soctherm: OC ALARM 0x00000001
[ 2587.686595] soctherm: OC ALARM 0x00000001
[ 2604.912374] soctherm: OC ALARM 0x00000001
[ 2707.878615] soctherm: OC ALARM 0x00000001
[ 2837.682451] soctherm: OC ALARM 0x00000001
[ 2931.492732] soctherm: OC ALARM 0x00000001
[ 2967.681429] soctherm: OC ALARM 0x00000001
[ 3227.681837] soctherm: OC ALARM 0x00000001
[ 3330.912752] soctherm: OC ALARM 0x00000001
Note: it took a lot of time to reach here and its stuck, please take a look
This method is just to provide you an interface that can access your board.
The system is waiting for you to login as this one showed.
Please use your account to login and then share me the dmesg and /var/log/Xorg.0.log.
It looks like system is still fine but maybe the graphic driver has some problem. That is why I need further log.
After following the techniques you showed fixed the issue of display, after that when i change the boot logo it doesnot work and the Jetson nano display is gone.
jetpack 6.4.3 was being used during flashing.
But at the same time the jetson nano which we received and didnt have display issue, its logo is changed very easily and its working perfectly fine, but the jetson nano which i flashed is having problem of boot logo. please check this issue and let me know if i am doing something wrong
Thank you
If original issue is already resolved, please file a new topic for your new issue.
We don’t use one topic to track everything …
@mohiz.ahmad
Just want to clarify because I saw you new post… are you talking about logo cannot show only or you are still talking about you cannot see anything on the monitor… I mean not just only boot logo…
i can see everything on the screen with boot logo as well after i followed the steps mentioned by you for flashing.
Now the issue is i cannot change boot logo (the picture of nvidia) on the devices which i flashed, and during changing boot logo it doesnot work and the display is again gone because of updating the logo
Now the Jetson nano which i had which didnot have display issue, there boot logo has been changed without any issue and its working fine but the issue which i am facing are those jetson nano’s which i flashed with SKDmanager using Jetpack 4.6.4
Are you talking about your device is dead again after you try to update boot logo with jp4.6.4?
i am not changing logo with JP4.6.4.
I used JP4.6.4 for flashing Jetson nano, this step is done, and display issue was resolved
Now the other issue is when i want to update the Boot logo it is unsuccessful after this when i try to turn on the Jetson nano i dont get any display. i hope this explains everything
and i have experience of changing boot logo and it works fine with the boards which was flashed by the company
about dead i dont know i think reflashing will resolve the display issue now i dont know why its hard for me to update the logo on the jetson nano dev kit which was flashed by me because i followed all the steps properly and still something is not working i hope you will understand my issue and suggest some solution
its been a great help thank you
