Hi!
When I boot up my nano, my monitor’s screen showed this error even i had restarted it multiple times
tegra-i2c 7000c400.i2c: no acknowledge from address 0x3c
Any idea why this happened? and how i can solve it ?
Hi!
Few questions/requests
Please dump serial console log.
Jetson/General debug - eLinux.org
Please indicate you are using sdcard based nano or emmc based.
This error means the rootfs is probably broken. Did you install anything or try anything and cause this problem?
If you didn’t, then hardware defect is also possible reason.
It’s been working for 3-6 months ever since I flashed it using sd card.
Yea, I did try to install tensorflow cuda and sdkmanager (at that moment, my disk space is fully occupied)
If you have other sdcard, please try to use that sdcard and flash it with sdkmanager.
Hi @WayneWWW
What if I dun have any Linux ubuntu os desktop?
Can i download sdkmanager on windows ?
Unfortunately, sdkmanager does not support on Windows host. Please find another host for sdkmanager.
Or you could use sdcard Image on another sdcard and see if this issue happens even on another sdcard.
