I purchased jetson nano before 3 days ago.
[0000.588] Send command failed with 0x3
Please try
- Different sdcard
- Try to use sdkmanager.
Before error generate, I connected ethernet cable to jetson and I could find the display is off after 30 minutes.
I tested using the new SD card: Kingston SD XC 1 : 32G, but the result is same.
the first sdcard is Sandisk: HC 1 : 64G: which operated in first use.
Is it possible to damage the sdcard port of jetson nano?
I got the same error messages when I turn on jetson without sdcard.
And I tried to use sdkmanager in ubuntu18.04 VM, but there is also errors when flashing to jetson.
Can you tell me what is the reason?
Can I return this jetson nano and get new one?
Sdkmanager cannot work on VM. I think you may need to find a host for it.
