Jetson Nano fails to boot and cannot enter the system
my Jetson Nano does not turn on,Some informations:
  • 5V power supply;
  • tried to change monitor, HDMI cable ;
  • reformatted micro sd and rewrote the image;
    *led has been lit
    *When the serial log prints this information, then it does nothing
    *Sometimes when I connect it to HDMI it doesn’t start, when I unplug it it starts up
This is the serial log:
Y @%Y H0TdFbaBoNp] (tercioL . `" !0 d4p(c%$@cA0
[ 0.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x211fe7
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.270] Read GPT from (4:0)
[0000.273] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.283] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.290] Number of retries left 4
[0000.293] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.303] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.310] Number of retries left 3
[0000.313] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.323] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.330] Number of retries left 2
[0000.333] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.343] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.350] Number of retries left 1
[0000.353] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.363] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.370] Number of retries left 0
[0000.373] Send command failed with 0x3
[0000.376] CMD8 send failed. Retrying CMD0/CMD8 (2)…
[0000.381] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.392] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.398] Number of retries left 4
[0000.401] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.412] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.418] Number of retries left 3
[0000.421] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.432] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.438] Number of retries left 2
[0000.441] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.452] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.458] Number of retries left 1
[0000.461] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.472] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.478] Number of retries left 0
[0000.481] Send command failed with 0x3
[0000.485] CMD8 send failed. Retrying CMD0/CMD8 (1)…
[0000.490] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.500] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.506] Number of retries left 4
[0000.510] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.520] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.526] Number of retries left 3
[0000.530] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.540] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.546] Number of retries left 2
[0000.550] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.560] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.566] Number of retries left 1
[0000.570] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.580] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.586] Number of retries left 0
[0000.590] Send command failed with 0x3
[0000.593] CMD8 send failed. Retrying CMD0/CMD8 (0)…
[0000.598] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.608] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.615] Number of retries left 4
[0000.618] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.628] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.635] Number of retries left 3
[0000.638] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.648] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.655] Number of retries left 2
[0000.658] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.668] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.675] Number of retries left 1
[0000.678] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.688] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.695] Number of retries left 0
[0000.698] Send command failed with 0x3
[0000.701] CMD55 send failed with error 0x3 in SdIdentifyCard func at 1870 line
[0000.708] SD Identify card failed with 0x3
[0000.712] SdIdentifyCard has failed with error 0x3 in NvTbootSdmmcInit func at 87 line
[0000.720] Sdmmc Init failed with 0x3 error
[0000.724] Read PT from (2:0)
[0000.739] Using BFS PT to query partitions
[0000.743] PT: Partition TBC NOT found !
[0000.747] Warning: Find Partition via PT Failed
[0000.751] failed to load NvTbootTbootCpu from (4:0)
[0000.756] re-load NvTbootTbootCpu from (2:0)
[0000.760] Read GPT from (4:0)
[000 .764] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.774] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.780] Number of retries left 4
[0000.784] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.794] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.800] Number of retries left 3
[0000.804] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.814] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.820] Number of retries left 2
[0000.824] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.834] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.840] Number of retries left 1
[0000.844] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.854] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.860] Number of retries left 0
[0000.863] Send command failed with 0x3
[0000.867] CMD8 send failed. Retrying CMD0/CMD8 (2)…
[0000.872] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.882] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.889] Number of retries left 4
[0000.892] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.902] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.909] Number of retries left 3
[0000.912] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.922] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.929] Number of retries left 2
[0000.932] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.942] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.949] Number of retries left 1
[0000.952] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.962] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.969] Number of retries left 0
[0000.972] Send command failed with 0x3
[0000.975] CMD8 send failed. Retrying CMD0/CMD8 (1)…
[0000.980] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.991] Command complete wait failed with error 0x3 Interrupt 0x18000
[0000.997] Number of retries left 4
[0001.000] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.011] Command complete wait failed with error 0x3 Interrupt 0x18001
[0001.017] Number of retries left 3
[0001.021] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.031] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.037] Number of retries left 2
[0001.041] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.051] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.057] Number of retries left 1
[0001.061] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.071] Command complete wait failed with error 0x3 Interrupt 0x18001
[0001.077] Number of retries left 0
[0001.080] Send command failed with 0x3
[0001.084] CMD8 send failed. Retrying CMD0/CMD8 (0)…
[0001.089] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.099] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.105] Number of retries left 4
[0001.109] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.119] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.125] Number of retries left 3
[0001.129] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.139] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.145] Number of retries left 2
[0001.149] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.159] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.165] Number of retries left 1
[0001.169] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.179] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.185] Number of retries left 0
[0001.189] Send command failed with 0x3
[0001.192] CMD55 send failed with error 0x3 in SdIdentifyCard func at 1870 line
[0001.199] SD Identify card failed with 0x3
[0001.203] SdIdentifyCard has failed with error 0x3 in NvTbootSdmmcInit func at 87 line
[0001.211] Sdmmc Init failed with 0x3 error
[0001.215] PT: Partition TBC NOT found !
[0001.218] Warning: Find Partition via PT Failed
[0001.223] Read GPT from (4:0)
[0001.226] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.236] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.243] Number of retries left 4
[0001.246] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.256] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.263] Number of retries left 3
[0001.266] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.276] Command complete wait failed with error 0x3 Interrupt 0x18001
[0001.283] Number of retries left 2
[0001.286] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.296] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.303] Number of retries left 1
[0001.306] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.316] Command complete wait failed with error 0x3 Interrupt 0x18001
[0001.323] Number of retries left 0
[0001.326] Send command failed with 0x3
[0001.330] CMD8 send failed. Retrying CMD0/CMD8 (2)…
[0001.335] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.345] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.351] Number of retries left 4
[0001.355] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.365] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.371] Number of retries left 3
[0001.375] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.385] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.391] Number of retries left 2
[0001.395] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.405] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.411] Number of retries left 1
[0001.415] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.425] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.431] Number of retries left 0
[0001.435] Send command failed with 0x3
[0001.438] CMD8 send failed. Retrying CMD0/CMD8 (1)…
[0001.443] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.453] Command complete wait failed with error 0x3 Interrupt 0x18001
[0001.460] Number of retries left 4
[0001.463] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.473] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.480] Number of retries left 3
[0001.483] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.494] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.500] Number of retries left 2
[0001.503] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.514] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.520] Number of retries left 1
[0001.523] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.534] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.540] Number of retries left 0
[0001.543] Send command failed with 0x3
[0001.547] CMD8 send failed. Retrying CMD0/CMD8 (0)…
[0001.552] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.562] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.568] Number of retries left 4
[0001.572] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.582] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.588] Number of retries left 3
[0001.592] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.602] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.608] Number of retries left 2
[0001.612] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.622] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.628] Number of retries left 1
[0001.632] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0001.642] Command complete wait failed with error 0x3 Interrupt 0x18000
[0001.648] Number of retries left 0
[0001.652] Send command failed with 0x3
[0001.655] CMD55 send failed with error 0x3 in SdIdentifyCard func at 1870 line
[0001.662] SD Identify card failed with 0x3
[0001.666] SdIdentifyCard has failed with error 0x3 in NvTbootSdmmcInit func at 87 line
[0001.674] Sdmmc Init failed with 0x3 error
[0001.678] PT: Partition TBC NOT found !
[0001.681] Warning: Find Partition via PT Failed
[0001.686] Error is 1
Please flash your board with sdkmanager instead of using sdcard image.
