After I put on the sd card, hdmi, ethernet, mouse&keyboard wireless adapter and power with 5V/4A power supply, I see the green led is on, monitor shows the logo, then about a few second it give me the error as follow:
Did you use Mac to burn the image onto the card?
I had issue with when I used Etcher, but when I followed the second step (of using terminal), it worked for me.
I have very limited understanding of the system, but based on the time I have ever used resolv.conf was when I was setting up wifi on Raspberry Pi. Maybe take out the wifi adapter and just plug in the ethernet to see if that works?
Remember that you will need two jumpers, a barrel jack power supply, a microusb cable and optionally an ethernet cable to connect to your modem and download the jetpack.
Doing it through the sdk manager is much better and you can check what is going on in the terminal.
