Unable to bootup in Jetson 2GB Nano
Hi all,
we are able to flash the SD card image as mentioned in portal → Jetson Nano 2GB Developer Kit - Get Started | NVIDIA Developer
& up and running 2GB Jetson Nano board for our on going activities.
after few months Nano board suddenly behaves different,
When I switch on the Nano, I am not able to visualize the log in interface. Sometimes I get “no signal” on the screen and sometimes the Nvidia Logo, as you can see in the attached image. For your information, the green light on the board is working and mouse and keyboard are powered.
we tried to reflashed the SD image on same 2GB Jetson Nano, but getting same error only.
Please let me know if I missed any here,
Thanks in Advance.
Regards,
L V Giribabu.
Please re-flash with SDK Manager.
Some issues cannot be fixed by just flashing with the SD card image.
Sure, will check it out & let u know…
Thanks for ur quick reply…
Regards,
L V Giribabu.
Hi Dave,
Can you please provide any link/portal for re-flash with SDK manager procedure for Jetson Nano 2GB boards?
You can easily Google and find it:
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
Thank you very much…
regards,
L V Giribabu.
Hi Dave,
Yes, now we are able to re-flashed the Nano 2GB with SDK manager as you mentioned.
Thank you very much for your support.
Regards,
L V GiriBabu.
