Jetson nano 2gb a02 board stuck at nvidia logo
Even if I change the SD card and continue to flash the image file, it stops the same.
Is there any other way?
I flashed the image file with the file name below.
jetson-nano-2gb-jp45-sd-card-image
jetson-nano-2gb-jp461-sd-card-image
Or is there a separate image file for the nano 2gb A02?
please do a whole re-flash with SDK Manager first.
It the bootloader gets corrupted, it won’t get recovered no matter how many times you flash only the SD card.
Thank you for answer!
Is there anywhere I can find out how to do a full flash using the SDK manager?
You may follow this guide:
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
thanks for the answer Thanks to you, I came this far.
Another problem arose.
As shown in the picture above, the target operating system is not activated.
Do I need to install it separately?
Sorry for being a beginner.
For flashing Jetson Nano, please use Ubuntu 16.04 or 18.04. 22.04 is not supported.
